Question about Vehicle Parts & Accessories
Keyless entry I have fitted central locking, also trunk release (button controlled). Ihave also fitted keyless entry... A ll work OK, but.....I have two wires left to fit. Pink marked (-) trunk release output, and Blue marked (+) flash output . how do I connect both, and where? Appreciate all help Thanks Geo'
  • 1 more comment
  • geo0722 Mar 01, 2009
    I assume "parking lights " mean R & L indicator lights? If so, where do I connect them with the relay. To one light or link them?
    Thanks
  • geo0722 Mar 02, 2009
    Thanks, I understand how to connect to lghts now, but my car is european Citroen C1 Vibe, and no parking lights as such each side. I need to connect to the 6 direction indicators which become hazard warning lights when the switch is operated on dashboard. The flasher unit is incorporated in the instrument panel, and not the old fashioned silver coloured can type which had 3 terminals. So I can't connect to it.
    Would it be possible to connect a relay from behind the dashboard Hazard warning switch?......Thanks for the great help so far.
    Forgot to tell you....
    The Pink is marked (-) trunk release output (0.5a).
    "" Blue "" "" (+) flash output (5a).
    Do I insert fuses between?, and where?
  • 95 Answers
Trunk release wire goes to the trunk wire of the vehicle and the flash output goes to your parking lights. Now if the trunk release is a positive wire than you will have to put a relay in to make it positive and if your parking lights are negative than you will have to put a relay in to make it negative.
Posted on Mar 01, 2009
  • 1 more comment
  • james kappers
    james kappers Mar 02, 2009
    you must use two relays, one for each light. take two relays and tape them together. take your parking light output and hook it to the #86 terminal on both relays. You can take a jumper wire to both terminals and then off for the parking light output from the remote start. Than take a ground wire and hook it up to #85 termilan on both relays, Then on Terminal #87 hook up a 12v constant on both relays. Than on the #30 terminal that will be your output wires for both lights, one for the left and one for the right. This will isolate each one and have them both turn on durning remote start.
  • james kappers
    that diagram only goes for ir f your vehicle calls for you to isolate your two lights. What type of vehicle is this going in because most cars are a one wire hook up for both lights
  • james kappers
    james kappers Mar 03, 2009
    no you do not need to add the fuses as they are internal. If you look at your light switch there should be parking liights. If you turn on your parking lights test the wires and see which one switches either + to - or - to +. That wire will be the one you hook up. If its negative you would have to put a relay to make it negative. Let me know what you find.
Trunk release for 98 pont gp no power, can't find the fuse and the switch itself was checked and was good
Check trunk release solenoid for power and ground when applied from switch. If power and ground ok, then release solenoid is the problem in the trunk lock mechanism. If misssing power or ground, then electrical diagnostics will be required
May 15, 2015 | Cars & Trucks
1994 buick lesabre trunk lock-how can I open the trunk without using a key. the key doesn't work although it open the doors to the car. is there a release button somewhere? we do not have the r
If it has the electric trunk release, the button could be in the glove box.
Otherwise you may have to remove the back seat to gain entry to the trunk.
Jun 17, 2013 | 1994 Buick LeSabre
My turn left signal stays on
possibly your keyless entry module keeping both front and rear lights on one side on. or indicator (flasher can) relay
remove flasher can and see if fault still there?
no - flasher can
yes - possibly keyless entry module/central door locking module or short to power on that circuit
remove now keyless entry modle to see if fault still there
no - that module
yes - try next module if fitted or if not find short in wiring.
Jan 20, 2011 | 1999 Isuzu Trooper
On a 2001 ford focus zx3 the keyless trunk entry doesn't work
i honestly am guessing,can you turn key to the left from vertical or right from vertical,if so one (left or right)is to lock trunk so you can give your keys to valet parkers....
May 22, 2010 | 2001 Ford Focus
Need to know how to program keyless remote on 98 cavalier
1997 Cavalier remote keyless entry programming.
All Remote Keyless Entry Modules may be programmed to receive four different
transmitters which all may be used to operate the remote control lock system on the
vehicle.
Also, severalvehicles, each with the same system may all be programmed to operate from the same transmitter or four different transmitters.
Step 1. Turn ignition off
Step 2. Ground the program pin.(within one second, Lock, Unlock and Trunk will cycle to indicate module ready for programming.)
**the program pin is the two wire connector plugged into the RKE reciever in the trunk of the vehicle at the Left Wheelhouse. Leave the main harness plugged in but unhook the two wire connector and ground the pins.**
Step 3. Press and hold the LOCK and UNLOCK buttons until:
Lock, Unlock, Trunk, and Horn cycles to indicate the transmitter has successfully been programmed. (This takes no more then 12 seconds)
Step 4. Repeat step 3 for the remaining number of transmitters
Step 5. Remove the ground from the program pin.
Step 6. Verify proper operation of the transmitters.
Keep in mind that 97-99 can be programmed by the owner, 00+ require DEALER programming with the scantool.
I hope helps with this (remember rated this help) Good luck.
Dec 29, 2009 | 1998 Chevrolet Cavalier
Need help programing two keyless entry remotes
Enter the keyless entry code on the door keypad 3 times. Locks will cycle down and up after the third time. Press and release the "lock" button. Locks should cycle again. May need to hold down lock button for 2 sec rather than press and release. Program up to 4 remotes. If cycling the key on-then-off works, you'll probably have to do it quickly 8 times and after the 8th time, locks will cycle down then up and press and release the lock button.
Apr 12, 2009 | 1998 Lincoln Continental
Car will not unlock.
To get inside the car .... Use the key in the lock cylinder, unlock the drivers door to get inside. You shouldn't have to reprogram the fob unless it or the keyless module was changed. There may be a blown fuse that supplies the keyless control module (check the owners manual for location). or wires that lead into the Drivers door may be damaged ... The keyless module is located inside the drivers door at the bottom behind the door panel ... do the unlock/lock and trunk release switches on the inside of the drivers door operate the locks and or trunk release? If so it is not the fuse ... and not the wires to it ... And it could be your BCM body control module, located in the dash board to right of your gas petal. Because the number entry keypad (code for that is on the inside of the right passenger trunk bracket arm) also doesn't work I assume it's not the key fobs themselves. Your 98 manual is correct for your car.
Apr 02, 2009 | 1998 Mercury Grand Marquis
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
1990 Olds 98 Regency Brougham - Programming Keyless Entry
Same car same problem, but I found the plug w/two wires behind the glove box. It is on a brace on the left hand side, has a clip holding it there. Lift up on the clip and it slides off.
I jumpered those two wires, the door locks did not cycle as was in the instructions and remote still doesn't work.
Sounds to me like I'm missing power from somewhere, but where?
Hope you find your wires and they work for you.
Nov 10, 2008 | 1990 Oldsmobile Regency
Programing keyless entry
If you have an owners manual the programming instructions are in there. If no manual here they are:
1. Turn the ignition off.
2. Ground the receiver program terminal. Jump the two terminals located in the programing ground connector. (What this means in simple terms is locate the wires that run on the right side of the trunk. There is two black wires that has a plug on the end with two prongs. It is in between the antenna and tail lights.)
3. Within 2 seconds of connecting the prongs the door locks will lock. The unlock and the rear compartment lid release will produce a cycle, causing the horn to chirp. This indicates that the module is ready for reprogramming.
4. Press and hold the lock and unlock buttons at the same time until the doors lock and unlock. The rear compartment lid will release and the horn sounds to indicate that the transmitter has successfully been reprogrammed. (Hold buttons down for approximately 12 seconds)
5. Repeat the previous step for the remaining transmitters.
6. Remove the jumper at the program connector.
7. Verify the proper operation of each transmitter
Sep 30, 2008 | 2007 Chevrolet Malibu SS Sedan New Cars
Vehicle Parts & Accessories Logo
227 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
