Question about Canon IXUS 80 IS Digital Camera
E 18 problem
The lens on my Canon digital camera will not close... i am unable to take a pciture and do not know the reason for this....when the camera is put on i am able to see my old pictures but when i click to take a new picture the screen is blank..i dont know what to do...please help...i have the canon power shot sd 500 camera and the problem that appears is the E18...... please help me Had the same "lens error, restart camera" with our Ixus 80 IS. Only one week old! Turns out there was sand (and a lot if it!) inside the camera (was used for taking pictures on a windy construction site). This sand had also made its way into the gear box. The solutions on this site helped me in determining the problem. The beneath mentioned PDF with photos was clearifying, although our camera's inside was somewhat different. By fully disassembling the gear box, cleaning each individual gear and using a can of compressed air to get rid of the remaining sand inside, I was able to make the camera work again. Thanx for the posted solutions! Marty
t00nz
  • 4738 Answers
SOURCE: E 18 problem
Your first problem sounds like a defective CCD imager. If your camera was an S300 Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Unfortunately, you mention that your camera is an SD300. That model camera is not currently on the recall list. But you might want to call Canon anyways. You might get lucky as the problem sure sounds familiar to the recall (excuse me, advisory hehehe).
As for the SD500 with the E18 error, try http://www.e18error.com/repair.html
Posted on Nov 15, 2007
Nick Spirov
  • 35 Answers
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: Ixus 700 (similar E18)
jengamb
go to fotogeeks.com (I think it is) I only saw it this morning a full photo layout of how to get to the lens and clean up the parts involved, might take some time but would be worth fixing. If you don't find it let me know
Posted on Feb 09, 2008
Same problem - gray screen, error message of E18 in bottom left corner. Unable to take pictures and lens will not retract.
Posted on Sep 29, 2008
  • 56 Answers
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Posted on Jan 26, 2009
E 18 problem
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
Please follow the directions found here.
Jan 07, 2008 | Canon PowerShot A570 IS Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
E 18 problem
Jan 08, 2009 | Cameras
E 18 problem
Try to use a diffrent memory card it will fix the problem
Aug 04, 2008 | Cameras
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
Jul 15, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
I just had the same problem. I sent the camera to the factory repair place and they fixed it in 5 days free. Even tho the camera is two years old and out of warranty.
Mar 01, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon IXUS 80 IS Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
