Question about RCA P52926 52" Rear Projection Television
Cleaning rear projection screen tv
How do u clean the mirror and with what
  • Chuck May 11, 2010
    No need to worry about elctricity just unplug from the wall. Now there are screws going around the perimeter of the plastic shell. You must remove all these. Now the shell will lift off in a vertical position. Now you can reach the mirror and cleand it with a lint free cloth (microfibre) and glass cleaner. Now if you can get to the guns (3 big lenses) you can clean these as well with a lens cleaner. Or lcd tv cleaner wipes. do not clean the actual vertical screen with anything. Just clean what i stated before. Now just put back together in reverse. You should clean these tvs like this once every 2 years or more if you smoke in the house.
  • 42 Answers
It is very rare to have to clean the mirror. It us upside down so it does not collect dust. It does however collect nicotine if there is a smoker in the house. Some RCA mirrors are not glass and should not be touched. The lenses do get dusty and should be cleaned.
Posted on Mar 06, 2009
SOURCE: Cleaning tv screen
need to know how to clean a hitachi rear projection screen tv
Posted on Apr 05, 2008
  • 4102 Answers
SOURCE: cleaning rear projection screen
Hi i was in the chat session with you just now if your telly is hd compatible then its obvious you can get hd quality picture and sound as dvd do hd sky and cable do hd channels and also games consoles do hd picture and sound if your telly doesnt say hd then it wont get hd quality pictures and sound.
If it is hd then you need to have hd leads running from the equipment to your telly so that your telly know that its hd signal.
Your telly if it is hd compatible it will have this option in the menu acessed via the tv controll.
You can only recieve hd quality if you have hd equipment or hd equipment that picks up hd signal from cable tv or sky tv.
So if your telly is hd then it has to have a way of recieving hd signal now if you only have scart sockets and the coloured sockets and you have looked for a flap that opens up on the back or either side or on the front of telly if you find no hd socket its about the size of usb port then the only way is through the coloured sockets you will need to get the correct leads and equipment needed make sure your telly is hd before buying any leads when you buy them take make and model of telly with you so they can cross referance the leads with your telly.
Hope this is helping you with your problem let me know if you need further assistance ok
Posted on Feb 11, 2008
SOURCE: rear projection clean mirror
I just cleaned my 4 year old panasonic PT47WXC43G's mirror and bulbs using alcohol free baby wipes and a microfiber cloth to dry them off. I did this because my tv started to look like crap. The picture was extremely foggy. I had incredible success doing this! Saved me about 2 grand. Now I don't have to buy a new TV now! My picture looks just like it did the day I bought the TV....If not better!
Posted on Feb 28, 2008
ctf1800
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
SOURCE: Cleaning mirrors and lenses on Sony big-screen projection TV
it's fairly easy to remove the screws on the back bottom portion of any rear-projector television. when the bottom part is removed, you will see both the mirror and the 3 lens. isopropyl alcohol or windex should do an efficient job. a soft lens rag can be found at any camera store. i'd spray the lens rag instead of the actual lens or mirror when doing this job.
Posted on Sep 16, 2008
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
My sanding 55 in rear projection tv has several hundred dots on the screen and getting worse each day. How can this be fixed?
u need to unplug tv, remove cover of upper back portion which is behind the screen. u will see a mirror fitted on inside of back cover clean both screen, mirror. u will also find on bottom side 3 picture tubes. clean them as well.
Aug 25, 2011 | Samsung Televison & Video
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Spider web inside tv
You need to open and clean it carefully.
  1. remove the back bottom panel
  2. Remove the top back panel (carefully the mirror is on it)
  3. Clean the mirror and the lenses (on the mirror don't use products with ammoniac) "a good tip is to use same staff to clean photographic cameras"
  4. Place back the top rear panel
  5. place back the bottom rear panel
Nov 09, 2008 | Samsung PCH521R 52" Rear Projection...
Mar 31, 2008 | Televison & Video
Cleaning tv screen
Mar 05, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
464 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
