Question about GE JVM1440 Microwave Oven
GE JVM1440 doesn't work, appears to be the primary interlock
Repeat poster GE JVM1440
The video was super and got me where I needed to go. I found the switch is fine but the primary interlock does not make contact with the switch when the door is closed. The top piece rotates and moves the bottom piece (again, primary interlock ) but the bottom piece doesn't push down far enough to cause the switch to .. switch.
I can do it manually and the machine runs.
I've tried manipulating the interlock pieces but only succeeded in causing the top piece to pop away from the chassis.
I don't believe the switch needs replacing, don't see screws that anchor the interlock pieces.
Do you sell the primary interlock pieces? I'd guess looking at a new set would help me understand how they are installed.
thanks for your help.
  • GE Master
  • 9,098 Answers
I would refer you back to my solution here. It has links for ordering parts, and it talks about securing your door switch to its mount, etc. You may need to realign things, too.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 02, 2009
Primary interlock switch
My GE JVM1850 microwave turns on when you open the door and when the door is shut and you try to put in a time and hit start it blows the breaker
Jul 13, 2013 | GE JVM1850 1000 Watts Microwave Oven
Ge microwave light wont turn off and when door is closed fan goes on
There are interlocking door switches that become defective and is part of the fail safe system.
Mar 21, 2012 | GE JVM1440 Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave stopped heating
Please remove the cover and check the door safety interlock switches found near the latch.
When these switches fail, the oven has no way to know the door is closed and will not turn on the heat. They go bad because we open the door with the door running and there is a arc on the tiny contacts.
There are other reasons for this condition ... this is the most common. Check them. If they are GOOD, repost your question stating you have inspected and tested the switches with a volt/ohm meter and they were good.
Thanks for your interest in FixYa.com
Feb 24, 2010 | GE JVM1440 Microwave Oven
Microwave runs when door is opened
Dont run it with the door open....The microwave are not good for you...You have an interlock switch problem...They can be adjusted...Sounds like one is stuck or bad in the closed position...Again do not run with door open......
Aug 08, 2009 | GE JVM1440 Microwave Oven
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
GE JVM1440 just stopped working.
This is almost always the primary interlock (bottom door switch) or its mount is loose or cracked.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jan 31, 2009 | GE JVM1440 Microwave Oven
GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 18, 2009 | GE JVM1440 Microwave Oven
PART needed for MICROWAVE OVEN GE JES1142SF 1100 WATTS.
It's odd, but they only list two or three parts for this model so far!
Standard interlock door switches should work.
You should be able to get switches from local appliance parts
stores, hardware stores, home improvement centers, etc.
Or I can send you one for $5.00 postpaid.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 06, 2008 | GE JES1142SF Microwave Oven
GE JVM1440 Microwave Oven Logo
186 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
