Question about Tomtom ONE GPS Receiver
Updated maps now tomtom710 will not store data
Hi,bought update from tomtom £69.00 found my sd card too small bought new sd 2gb installed updtaae now my tom tom gives error
"cannot store settings.".
  • 47 Answers
Blet, nafik, just push that small & stupid switch on the upper left, to top, on SD card. It will mean that you switched off "write protected" mode on you SD card ;)
Or, make sure you have SanDisk make SD card ;)
Posted on Mar 01, 2009
  • soras46 Mar 01, 2009
    if this doesn't help, then change your NavCore (it's like TT OS)
I tried to update my tomtom go live 750 inthe mid of installation it says no enough space then i canceled after that my device shows on screen no maps found i bought the device end of december 2009, any...
In the Memory slot at the bottom of your TomTom (Go 750) insert a 4GB MicroSD memory card and download Europe 2GB from your TomTom update. It worked for me Good luck !!
Jan 21, 2010 | Tomtom GO 750 LIVE GPS Receiver
New purchased North america map.
I am assuming that, without being a GEEK, you are sufficiently proficient with a computer. I will describe the procedure with all the necessary details. I use Windows XP and all folders I refer to are in Windows OS hierarchy. I have tried all except starting from the SD card, I happen not to have a 2GB card ready.
I suggest you read the whole post, think about its feasability from your point of view, and proceed from there. If you have any misgivings about what I say, DO NOT DO IT. I shall NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR GPS.
First of all you should install the HOME application on your computer. Then you connect your GPS to the computer. When it asks you if you want to connect to the computer tap YES, and the HOME application will launch. You may let it perform an update (if any ) of the OS (application that manages the GPS). Do not let it make any update of the OLD map. On each screen you have a CANCEL button.
Use the TomTom Home Application to backup your device. The backup will be stored on your computer, and you will be able to restore it in case of a problems.
Disconnect your GPS and insert the SD Card in slot. Then connect the GPS to the computer and let it communicate with the HOME application.
When HOME launches it will show you the internal memory of the GPS and the SD card and you are asked to select from where to run the device. Select the external SD card.
If any thing goes wrong STOP.
In the main window of the HOME application use the right arrow to go to go to Backup and restore icon. Click the icon, HOME will restore the application and the old map, all that is on the internal memory.
If that does not work, I think you should copy the content of the backup folder \My Documents\TomTom\HOME\Backup\GO\Backup01 on the SD card. and try restarting the system from the external card.
What remains to be done is to look for the new map and put at the right place in the HOME folder.
Here I will show you the directory hierarchy in WindowsXP
On my computer the map is
\My Documents\TomTom\HOME\Download\complete\map
In this directory there is folder called North_America_2GB. It contains a 1kB activation Zip archive file, a 1.5GB map zip archive, a 6kB table of contents (. toc file) and two image files.
Once the application and the map are on the external SD card you should be able to start the device from the internal memory or the SD card. When you turn it on you will probably see two icons (one of the internal mempory and the other for the SD card) . They will be flashing for a short while. You have to tap the one that you want to start with.
Jan 06, 2010 | Tomtom ONE GPS Receiver
I bought the new maps from website, and can not install
If the software crashed whilst updating, you will find that if you try to restore from a complete backup when you switch on next time it will either say you cant use the map or will just freeze, fix re format both the internal memory and the memory card, then find where tom tom home had stored the files, then using windows copy the contents from the 2 folders back into the relitive internal and external card, you will then find that you will get the mesage that you cant use the map, this is because tom tom home doesent always put the map data into the correct folder, to fix this find the licence data and the map data that has been stored on the sd card instead of the internal memory and copy it into the internal memory, before switching off press the reset button, when you switch on you should find that you have a working tom tom
Aug 25, 2009 | Tomtom ONE XL GPS
Unable to upload map of America
the version of the map is too old for your gps so that means that the map is too old or your gps is old
Apr 27, 2009 | Tomtom GO 510 GPS Receiver
The map cartridge fell out of the bottom of the Tom Tom.
Yes, it can be replaced, the map cartridge is a standard SD memory card.
These can be bought quite cheap in most camera/computer stores or in several department stores.
They can also be bought online from amazon See Here $6.65
Once you have the new card, connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Apr 05, 2009 | Tomtom One XL GPS Receiver
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Feb 24, 2009 | Tomtom One XL GPS Receiver
Loading TomTom one maps for northern France
First you need to have the relivent map on your SD card. Typicly this will be the Tomtom Map " Western Europe ". When you purchase maps from TomTom you also get an activation code and instructions telling you how to install the map onto your device and how to authorise it using the code that comes with it.
Before doing anything ... BACK-UP your existing data ( the whole SD card ) onto your computer . This will ensure that if any update is unsuccesful you can at least return things to the way they were before you tried to update.
There are several ways to obtain maps
  • buy a new TOMTOM SD card for your tomtom that containes the required maps. Make sure it comes with the authorisation card.
  • buy a CD from TomTom or a TomTom authorised dealer . This CD will contain the required map so you can download the required map to your own SD card. Make sure it comes with the authorisation code AND instructions.
  • buy the required map from TomTom online . You can download it to your PC , then copy it onto your SD card later. It will come with some instructions and authorisation code ...... You can also use "TomTom Home" software and this does most of the job of downloading maps ( that you buy from tomtom ) and puts them onto your sd card for you in a semi-automatic way . If you go down this route then its best to be sure you have the latest version of TomTom home software by going to the TomTom website first.
With ANY of the above methods------- BACK UP your existing SD card first . In fact ... make a BACK UP NOW , then if anything goes wrong at any time , you can at least revert back to your backup.
Good Luck
Jan 18, 2009 | Tomtom One Europe v2 GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Tomtom 300 software update deleted my maps
Hi Albert. Theres lots of data on the card besides the map that your tomtom needs in order for it to work. Theres really no solution can be offered as unfortunatly something has happened to the data on your card and something is either missing or corrupted. Exactly what would need to be investigated and its not really within the scope of doing so on this forum. Without any judgement to you or anyone else can I warn all other tomtom users ..... BACK UP YOUR SD CARD TO YOUR COMPUTER before you attempt any "update" to your tomtom. If you have made a backup Albert then I suggest you reload the backup onto your card and everything should work again. Fingers crossed. You might need to do a hard reset by pressing the reset button underneath your tomtom with a paper clip through the reset hole. Good luck.
Dec 29, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
66 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
