Question about Koolatron p65 Beverage Cooler
Koolatron P65 Noisey Fan sn 0013471
Can you help me replace the fan?
Don't know how to get it apart and don't know if it is a double shaft model or not?
Thanks ric
rica@can.rogers.com
22yooper
  • 828 Answers
SOURCE: Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
Posted on May 30, 2008
22yooper
  • 828 Answers
SOURCE: KOOLATRON VENDING MACHINE, FAN WILL NOT WORK
customer service helpline at 1-800-265-8456
  • 124 Answers
SOURCE: Koolatron P27.motor fan open.
Parts for most Koolatron units can be found at some of the larger truck stops. Like T/A
Look in the area where they have them on display, you will see the motor and power cords.
Posted on Aug 30, 2009
SOURCE: Cooler fan fried
I live in Canada and wasn't able to locate a replacement fan. With a little creativity however I was able to fit in the fan from an old computer. My 20 year old koolatron cooler works great again!
Posted on Jul 14, 2010
  • 407 Answers
SOURCE: KOOLATRON MODEL NO.P-25;FAN MOTOR BURNED
http://www.toolfetch.com/replacement-parts-das-70105.shtml
Try this.
Posted on May 12, 2011
Whirlpool Cabrio dryer is making a really loud noise and how do I fix it?
stephanie, the first thing you suspect is the fan belt. It could be slipping. 2nd suspect is the drum shaft that is misaligned. If you know what & how you are doing, you have to take the machine apart, find & replace parts. If you can't or don't know how, I suggest a repair man. If the repair is more then the value, worth of the machine, you should get another.I hope that this works
Nov 04, 2012 | Dryers
Blower motor resistor replacement 1999 chevrolet silverado
posible fan moter bearing or sometimes a foren object falls into the the housing
Nov 29, 2011 | 1999 Chevrolet Silverado 1500
How to replace drive shaft cable
Hi Chris, are you an unknown brother? Sorry I'm not clear about what you want to do. I don't know what cable you refer to and don't know of one on a drive shaft? What vehicle are you referring to and the model and year? Regards John
Nov 13, 2011 | Cars & Trucks
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
Having trouble taking down the fan have removed the light and the blades cannot get the motor assembly down
Don't know which brand ceiling fab you have, but almost all mount the same way. You have completed most of what needs to be done. So, now you need to remove the ceiling cowl, that slides up and down on the down rod. There should be 2-3 screws in the top outer edge of the cowl. If you remove those, the cowl will slide down the rod. After that, unscrew the wiring nuts, that connect the fan's wiring to the house wiring. Don't forget to disconnect the copper ground wire, too. Then the ball on the end of the down rod shaft can be lifted out of the ceiling bracket.
MOST IMPORTANTLY, DO NOT ATTEMPT TO DISCONNECT ANY WIRES UNTIL THE CIRCUIT BREAKER FOR THAT CEILING OUTLET IS TURNED OFF. DON'T JUST RELY ON THE WALL SWITCH BEING OFF.
Hope this helped you in the removal of the ceiling fan. Please let me know. Thanks.
May 23, 2011 | Heating & Cooling
Recently, the wine fridge has started to make a whirrring sound that lasts around 4 or 5 seconds, then stops for around 20 or 30 seconds, then starts whirrrring again. Sounds a bit like a man moaning....
it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Canby may be reached at the following link:
http://danby.com/customer_service
May 21, 2011 | Danby DWC283BLS Wine Cooler
Fan on woodstove not working regularly. Model no WOODSTOVE 1800/2400. Thanks, Brendan
Brendan, if you can access the blower remove it and clean it. Note if any lubrication of the fan's shaft needs lubrication (light weight machine oil will work). Also, check the outlet that the fan is plugged into, to make sure it' still has power. If it's an automatic fan that has a senor to turn it on and off, that sensor may have failed and will need to be replaced. Depending on the age of the wood stove and the blower assembly plays an big role in this. They don't last forever.
Apr 26, 2011 | Heating & Cooling
There is a horrible humming sound coming from the freezer. It seems to be the fan that is behind the piece of plastic in the middle of the back wall of freezer. The sticker in the freezer says MODELS...
Hard to diagnose without being there and taking it apart. Based on my experiences, I suspect the defrost drain could be restricted. The defrost water freezes in place around the fans shrould and the fan blade hits the ice buildup. If the ice builds up enough the fan blade will be stopped and possible damage the fan motor. Access fan area to inspect and defrost (hot water, hair dryer or let it stand overnight off. DC evaporator fan motor WR60X10228 est $85
Ric
Mar 09, 2010 | GE Profile Arctica Stainless Steel Top...
Freezer running at 0 to 10 below but fridg wont go below 42. Cold control tested good. Cleaned bottom was really dirty brushed an vacumed no improvement. Air flow from vent in rear of refrigator...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • the fan could also be the problem, and like you said a visual inspection of the fan should clarify that. sometimes the plastic fan blade gets loose on the metal shaft of the fan motor and it will not turn very fast.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 05, 2008 | GE Refrigerators
Koolatron p65 Beverage Cooler Logo
82 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
