Question about Carrier 38CKC042 Air Conditioner
The furnace starts up but does not run - Carrier 38CKC042 Air Conditioner
  • 1 more comment
  • Farley Redfield
    Farley Redfield May 11, 2010
    Skeeter is right need more info. Whats running whats not. What can you see hear and smell? When it starts up, whats starting?
  • Dave Dobransky May 11, 2010
    what does it do to "start up"?
  • Ken Bledsoe May 11, 2010
    Sounds like by your description the blower motor is shot. Need more info. Get back with me and we can trouble shoot this thing.
Sounds like blower motor capacitor is shorted out.
Posted on Mar 31, 2009
Furnaces starts on its own thermostat is off.
sounds like your thermostat is not working like it should. check to see if any wires are loose or broken
Jun 16, 2014 | Atwood 34,000 BTU 8500 IV Furnace
Had blackout and now furnace won't start
The biggest items to check after blackout are the circuit boards and the transformer. Also if the furnace was running when it happened, the unit could trip on limit...BUT if this happened the blower would run nonstop with no activity of heat. If no blower, you will need to start with 120v to furnace and then 24v from transformer.
May 11, 2010 | Coleman Propane Forced Air Heater...
Furnace will run, put out heat, turn off and doesnt start again.
What is model # & serial # of this furnace, it may have a diagnosis led indicator light located on the control board, behind bottom door of furnace which will blink and tell you a fault code. Also check furnace filter, make sure its clean, check through out the house to see if all registers are open and not blocked by any objects, make sure cold air return grill is not blocked, the unit could be over heating and shutting off on high limit, good luck.
Feb 15, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Carrier 38CKC042 Air Conditioner Logo
59 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
