Question about Plumbing
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes out of shower but when you release the shower both shower and faucet run
  • 3 more comments
  • arlenw Mar 07, 2009
    When I turn the water on, water comes out of both the faucet and shower head, when I pull up on the lever the water then comes out the shower head. As soon i as put the lever back down the water again comes outof both the faucet and the shower head.
  • neilwolson Apr 20, 2009
    In new bathroom, when I turn the water on, water comes out the shower and the lower nozzle. When I pull up on the shower lever, water comes out of shower and not the nozzle which is how it should be. How do I get the water to not come out of the shower when the shower lever is not pulled up? took the nozzle off so that water is just coming out of the lower pipe to help eliminate the nozzle as the problem. Same results.
  • James Sledge
    James Sledge May 11, 2010
    Is this a new faucet and what brand? One handle or two?
  • jpatzelt Oct 22, 2013
    This will also occur if the valve was installed upside down. If your home has decent water pressure, do not use pex tubing between the valve and the spout. The best choice is 1/2" galvanized pipe, which has twice capacity than pex. The valve is out putting more volume than the pex pipe can handle, which is why it backs up to the shower,
  • Anonymous Mar 20, 2014
    looking for discontinued satin nickel 2000.501.295 shower faucet trim
    Problem Solver:
  • 11 Answers
Depending upon which valve you used and how it was plumbed, you may need a twin elle or a specific part to match the ROHL pressure balance valve. if your second outlet is plumbed off the bottom of the valve, you need 18" of pipe between the valve and the outlet. Anything shorter than this and you can have back pressure issues.
Posted on Dec 18, 2014
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Posted on Mar 16, 2009
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Feb 26, 2010 | Delta & Leland Lavatory Faucet
When i turn on bath water it runs also from the shower if i pull lever up for just shower than just shower runs
You have more water trying to come out of the spout than the diverter gate will allow so by default it find another path of least resistance which is up the shower pipe to the head. I would suggest just getting a new tub spout. Remove it by unscrewing like you would a jar lid or it may have an allan set screw underneath and towards the rear.
Hope this helps and good luck.
Feb 05, 2010 | Delta & Tub & Shower Faucet
When I turn the water on for a bath only water
the water deverter that makes water come out the shower head is probably in need of repair. or replaced.
Dec 04, 2009 | Moen & One Handle Tub & Shower Faucet
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Plumbing Logo
846 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
