Question about RCA P52937 52" Rear Projection Television
RCA rear projection tv
RCA home theater premiere rear projection tv.small picture almost normal.big picture tv channel is not clear, vedio input no output ,s-vedio has output but every 20+seconds has a flash,thanks for your help free bird
  • Anonymous Mar 25, 2014
    Input and out put picture
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Posted on Sep 18, 2007
  • Anonymous Oct 02, 2007
    i need a part number for RCA Model:P52937 Chassis No.PTK195M26B or
    CTC195M2
    location on motherboard is 14101 Transistor PWR CHopper. i dont need this numbers 237476 or 237469 from service manual i need exect part number it self. Thank you in advance to all TV Repair Pros
SOURCE:
My rca home theater premiere 60" rear -projecton tv changes its channels without me doing anything
Ive seen that over the years . on the front of the set there are the push button switches . one of them have failed on the board . the tact switches can be replaced . if you can solder and have the skill and ability . or the other option is since most people live by the remote and do not get up to turn there set on or change channels . if you were to take the back off of the set you would look at the top center of the light box . there you will see a board with some cables running to it and since we don't have a model number from you i can not tell you exactly which cable it is but it will run to the push button board just unplug that there and you can use the remote and you should return to a normal operation .
Dec 28, 2014 | RCA P61950 61" Rear Projection Television
Rca home threatre premier will not turn on
if ur not getting a picture but the tv is blinking red at the bottom right or bittom left of the tv u may need to replace the blub this happen to me once and took care of the problem
Jun 03, 2012 | RCA P61960 61" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Rca television home theater premier 52' went out of focus how do i fix
unplug the TV for 4 hrs. and it will reset to factory settings maybe that will help and then you have to run setup again of course.
Jan 02, 2010 | RCA P52937 52" Rear Projection Television
No picture
Change the input on the TV to the input that you have the S or Composite (yellow) plugged into from the RCA
Channel 3 should be the cable or antenna input F connector.
Charles
Oct 30, 2008 | RCA RTDVD1 System
RCA BIG SCREEN TV - COLOR PROBLEM
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
May 30, 2008 | Audio Players & Recorders
RCA Home Theater Premiere
unplug the TV for 4 hrs. and let it reset to factory settings and then start from there scan for channel line up in the menu.
Jan 30, 2008 | RCA P52937 52" Rear Projection Television
Buzzing sound
I'm no Expert, but I have worked for a major statelite tv company for the past 7 years,one thing you can check besides the channels, would be the video inputs, see if you have the same issues with different components dvd vcr etc.. if so it would be narrowed to the tv or poss connections to the tele..
Oct 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
300 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
