Question about Proscan 26LB30QD 26 in. LCD HDTV
Surround will not work on proscan 26" flatscreen
Portable surround system will not work on the 26" proscan flatscreen.dont think there is an audio out for this
  • Anonymous Mar 27, 2014
    how can i get local free channels on proscan flatscreen
    President:
  • 814 Answers
This television has only one audio output. IT is a coax digital output listed as N on the back of the television.You will have to get a adaptor to use it with you portable surround sound. You Should be able to find one online. just google the type you need to the coax, and it should bring up places that sell them. If you cannot find one you can go to the PROSCAN website and use the customer support section to get help from them.You can also call them at 1-888-977-6722. It might be best to call them to make sure you get the correct adaptor for you use. I hope this helps you with your problem.
Posted on May 21, 2009
What audio out cord needed for proscan television.
Without a model number or picture I cannot tell you what you have available. That being said, you should have an audio left and right which will be RCA type connections. The other audio, not commonly used by home owners yet is the digital audio out. Either will work just fine.
Nov 29, 2015 | Proscan Televison & Video
Surround Sound
RED and White attachments are Audio. The Yellow is Video. Do not plug the Yellow into the Red/White/or black (if available). If you have HDMI, all of this would be solved with one cable attachment.
Mar 05, 2014 | Proscan Televison & Video
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Get no response from audio out to surround sound sytem my e-mail is jerryhusbands@yahoo.com
You need to give a lot more detail about you set-up. What type of surround sound Brand name and model number are you using. What type of connections are you using with the coaxial sound output to the surround sound system.Have you tested this coaxial output on another speaker source to make sure that it is not putting out sound. You can do this with a coaxial to rca adapter and use one of the receivers normal sound inputs to see if you are getting any sound from the output of the television.You also must make sure you are using the remote controls of the two components correctly. Check to make sure the volume is adjusted to a hearing level on both remotes.Check all the cables you are using and make sure they are working correctly. If after doing the testing you find that the television is not putting out sound. You will need to contact PROSCAN for customer support help.You can use their website at www.oncorpus.com. Go to the customer support section and ask for help with your problem. You can also call them at 1-888-977-6722. I hope this has helped you with your problem.
Apr 24, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Suround sound does not work on my 26" proscan
Hello Brian,
I understand your problem and I have a surround sound system hooked up to my TV and I think I might be able to help you because I have done this in the past.
RCA Setup Only
  1. On your TV you should see an Audio Out slot. Plug your RCA Cord into that slot.
  2. Then plug the RCA Cord to the Audio In slot on the Surround Sound System.
  3. Then, if your Surround System is the type with a DVD in it continue step 4.
  4. You should see a Yellow Video slot on the TV. Plug the Yellow RCA into that slot.
  5. If you do not have one of those, you would need to pick one up at a Electronics Store.
HDMI Setup Only
  1. Take the HDMI cord and plug on end into the slot on the TV.
  2. Take the other end of the HDMI cord and plug that into the slot on the Sound System.
I hope this helps you out.
If you have any questions, let me know
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Mar 01, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
Proscan 26LB30QD 26 in. LCD HDTV Logo
194 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
