Question about AT&T 6850G Router (ALL07735)
Windows Vista laptop cannot connect wirelessly ATT router 6850G
My other laptop with windows XP connects fine
I input WEP incription code but it doesnt like it!
  • 2 more comments
  • Carla Laughlin Mar 01, 2009
    Hi Emotionless
    I input the code 5 times so I dont think that is it
    Windows Firewall is on
    Thanks so much for helpimg me
    I disabled the firewall on Vista laptop as you sguuested and also unplugged the modem waited 10 seconds then rebooted Vista laptop
    still no go
  • EmotionLess
    EmotionLess May 11, 2010
    Try disabling the firewall and connecting, albeit it's a longshot, it was the solution when I have set up wirless to a friend of mine. After the first established connection I've enabled back the FW and it works great.
    Also, do you use the internal windows networking wizard to connect or some software provided by the wireless card manufacturer?
  • EmotionLess
    Have you correctly typed the code?
    Do you have some firewall installed on Vista laptop?
sandrew
  • 2961 Answers
SOURCE: Wireless device disappeared with Windows Vista installation
Unfortunately, you have mentioned the router, which is no longer supported on the Dell site, but not the network card you are trying to use, please advise so as we can try for a driver. I assume you have tried installing the XP driver, as sometimes this may or may not work.
Posted on Mar 16, 2007
bc_axys
  • 49 Answers
SOURCE: Connecting to a netgear DG834G with vista
Is this for wireless?
Go to Network and sharing center first then delete all netowrks under manage wireless network. then go to " connect to a network" and if able to see your network there then click conenct then type in wep key.
it is important also to make sure if the router still retain the same wep key you have now.
if this is not for wireless PC who is your internet service povider? is it cable? the authentication for cable is the mac address of the Main Pc which i believe in your case is the xp computer's  Mac adress.
 try checking your device (router) because there are routers that are not compatible with Vista.
Posted on Oct 13, 2007
watz up
  • 6 Answers
SOURCE: Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Posted on Sep 11, 2008
  • 1738 Answers
SOURCE: i don't have my network key, i want to connect my
First you need to create a administrator account on both computers. Make sure that you have ipx and spx protocols and both comptuer installs. Take you laptop back to your router and log into with the gateway address and go to the wireless tab. There you can create a network key, which is known as a password.
Posted on Nov 14, 2009
jineeshr
  • 70 Answers
SOURCE: I want to secure my Belkin 'n' wireless router . I
connect any one of the computers to the router with a ethernet cable. open internet explorer, clear out the address bar on the top, and type 192.168.2.1. when u hit enter, u'll get a router set up utility. in this page u'll have an option -security- below "wireless". when u click security, it'll ask for a password, leave it blank and hit submit. on the next window, choose the option WPA/WP2, then u'll have some more options, look for PASSWORD(PSK).. put in a password which should be 8 to 63 characters long, its case sensitive. click on apply changes.
Posted on Jan 10, 2010
Testimonial: "Thanks, this really helped and was step by step. "
I am getting Error Code 193 and then when I tried again, I got Error Code 999. I can not connect my router to my new laptop. Help. Dave
This article will guide user on what to do if could not connect to a wireless network using WEP. User encounters the following error message "Additional log on information is required to connect to this network" or "Validating Identity".
Instructions for Vista
Instructions for Windows XP
Instructions for Mac OS
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
Once I have enabled WEP, how do I set up the wireless clients to use the router? I have no idea how to configure the clients. I have a WIndows XP, 2 Vista machines and a Windows 7 laptop I need to...
Just connect to the network... Simply open the icon in the far bottom right hand corner ; with the 2 double little PC icon; WLAN icon . Right click >> Then "Connect to a Network" >> Look for your own wireless network >> then connect >> will ask for the WEP key - log it in >> Then Connect.
Mar 27, 2010 | Belkin (F5D5231-4) Router
My system can't detect the netgear router so, I can't connect. Error is view wireless network security setting for Netgear.
The network security depends on the operating system.
Windows 2000,xp-security:WEP
Windows vista,MAC-security:WPA.If your using for eg vista and xp then choose WEP as xp wont support WPA.
Nov 03, 2009 | Computers & Internet
Icouldn't access the internet. Your help tam, via
Please go in to your router and change the wireless setting from WPA2-PSK to WEP. Ansd then try to connect your laptop.
To windows after you change setting to WEP
(XP bottom right hand side you have system tray in that you have a wireless sign click on it. It ask for the password which you will change put that password click connect)
For laptop also same in case it not work then
(window icon>control panel>network and sharing center>wireless connection>properties>put the password click connect (then it will check out the wireless signal after sometime you will'be able to connect).
Hope this will resolve your issue.
Oct 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
I have two laptops: XP op. syst. on one, and Vista op syst on the
I would try using the hex value generated from your password by your WEP enabled router instead of the password itself. Windows has always been a little funny with WEP and I've always had better luck using the hex value my router generates.
Nov 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Apr 11, 2008 | D-Link DIR-625 (790069292637) Wireless...
AT&T 6850G Router (ALL07735) Logo
376 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
