Question about Proscan 26LB30QD 26 in. LCD HDTV
Suround sound does not work on my 26" proscan
I have a theatre sound system,can not find an audio out on tv.have it hooked to audio in. It does not work. HELP
  • Anonymous Mar 20, 2009
    i blew my speekers up and i need to find out what size of spekers i need
    Scholar:
  • 124 Answers
Hello Brian,
I understand your problem and I have a surround sound system hooked up to my TV and I think I might be able to help you because I have done this in the past.
RCA Setup Only
  1. On your TV you should see an Audio Out slot. Plug your RCA Cord into that slot.
  2. Then plug the RCA Cord to the Audio In slot on the Surround Sound System.
  3. Then, if your Surround System is the type with a DVD in it continue step 4.
  4. You should see a Yellow Video slot on the TV. Plug the Yellow RCA into that slot.
  5. If you do not have one of those, you would need to pick one up at a Electronics Store.
HDMI Setup Only
  1. Take the HDMI cord and plug on end into the slot on the TV.
  2. Take the other end of the HDMI cord and plug that into the slot on the Sound System.
I hope this helps you out.
If you have any questions, let me know
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Posted on Mar 01, 2009
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
Jan 16, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Is there a way to hook up the TV audio to a home theater system? Where is the audio out?
If you have a cable or satellite box, thats very easy to do, feed the audio from your box into the home theatre system. However, if your refering to just the audio coming out of the tv. Most Home entertain systems will allow you to plug the video line in with the audio line in, if your using basic cable, you have to use a VCR or DVR to access the sound, otherwise its impossible.
Dec 20, 2009 | Proscan PS32700 32" TV
How can you hook up external speakers to this TV?
youhave to have an audio reciever or powered speakers to do so
May 20, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't wire up to LG plasma HELP
Ah, I assume you have put rca's from the TV audio out to the Audio in of the Theatre System! Then put the Audio System to Aux 1 / 2 and you should have sound through your Theatre System!
Feb 20, 2008 | Sony DAV-S500 System
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
Proscan 26LB30QD 26 in. LCD HDTV Logo
277 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
