Question about Sony Ericsson Walkman W810i Cellular Phone
My w810i lcd is white
Hi my w810i lcd is white and i wonderd if u could help me repair it?
  • 2,335 Answers
When I had the white screen problem, I was about to replace my W810i before I found out about the Sony Ericsson Update Service (SEUS). I used it to fix the firmware inside my phone, even though the phone seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w810i?lc=en&cc=us
Posted on Sep 19, 2009
  • Paul Sager
    Paul Sager Sep 19, 2009
    If your computer recognizes your phone when you plug it in, & can read your memory stick for example, even though your screen is white, then I would agree with the other solution posted and consider replacing the lcd screen.
    If not, it is very likely flashing the firmware with SEUS will solve your problem.
    President:
  • 625 Answers
If the screen is white, there is a possibility that the connector for the lcd is not seated firmly.
The Sony W810i is not to hard to take apart.
I would take it apart, reseat the connector and see what happens. If this does not fix it then a new LCD Screen might.
Check out the following link for instructions and links to LCD screens
Sony W810i LCD Screen Replacement
Posted on Aug 21, 2009
  • Terry Fritsch
    Terry Fritsch Aug 21, 2009
    If you are seeing a white screen 1 of 2 things has happened. The
    connector for the LCD may have come loose or the LCD itself has gone
    bad.
    Checking out and replacing the LCD screen on the Sony W810i is a pretty straight forward procedure.
    I
    would take the phone apart and check the lcd connector first. Reseat it
    and try it out. If it is still white, your next step is to replace the
    LCD screen. This should then take care of the problem. A new LCD screen
    runs about 30 dollars from Ebay.
    Take a look at the following link to see instructions and links to buy the lcd screen
    Sony Ericsson W810 LCD Display Screen Replacement
    I hope that helps out
How to format w810i... all my software gone. when i on my fon... the screen white only !!! =.=
WHITS SCREEN DISPLAY.
hi,
there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
i hope ,i will help you ,thanks for trusting fixya...
Jul 07, 2010 | Sony Ericsson Walkman W810i Cellular Phone
No display but can still make and receive calls
Hi, this is a common problem with Sony Ericsson phones, there can be two problems:
1. The LCD screen needs to be replaced
2. The LCD screen ribbon has become loose
Either way just take it in your local phone shop and get it repaired.
Hope this helps
Muzzi_123
Nov 09, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Why is my se w810i coming on with a white screen?
That white screen means that your phone needs to flash over you will need to download xs++ to do so if you need any help email me
Thank you
God bless
Aug 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
I dropped my sony ericcson walkman
there is a loose connection or a broken signal path to the lcd..have a good technician fix it if it is still worth the fix
W810i can switch on but blank screen
May be video display chip has got damaged.
You need to replace it through any authorized service center.
Jul 09, 2009 | Sony Ericsson Walkman W810i Cellular Phone
W810i Broken Screen
Check out the following link for instructions for replacing your broken w810 LCD screen and link to buy the LCD screen from ebay.
W810 LCD Screen Replacement
May 10, 2009 | Sony Ericsson F305 White +512MB Unlocked...
My w810i phone shows up a white screen..my phone is 1.3 yrs old...i am unable to do anything..please help me...in this in concern..thanks in advance...!!
If your computer recognizes your phone when you plug it in, you may have a problem with the lcd screen.
When my Sony W810i had the white screen problem, I was about to buy a new phone when I found out about the Sony Ericsson Update Service (SEUS). I used it to fix the firmware inside my phone, even though the phone seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
Mar 15, 2009 | Sony Ericsson Walkman W810i Cellular Phone
W810i turned into white screen after USB transfer
go to www.topsony.com
jjdmio - you need to have the LCD or flexcable replaced take it to a mobile service center and have them fix it for you.
Mar 30, 2008 | Sony Ericsson Walkman W810i Cellular Phone
White screen sony ericsson w810i
i got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
it worked for me. I got all my contacts and messages back.
Good luck
-Manoj
Nov 03, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
305 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
