Question about HP nx9110 Notebook
HP NX9110 Won't turn on
Hi, My laptop is about 4 years old and just recently the laptop cuts out after a few seconds from turning on. Now, when the power button is pressed some lights flash and that's about it. I have taken out the battery and just used the AC but still no go.
Do I have to face facts and lay the laptop to rest or is there hope?
Cheers
  • Anonymous Mar 10, 2009
    the front light for the AC indicator (lighning bolt) just flashes on and off (orange), and i cannot even start the laptop...
  • 46 Answers
Your power jack may have become unsoldered from the main board after four years of plugging in and unplugging the AC adapter (and thus wiggling the jack). If the AC adapter seems to wobble a lot at the jack, this is most likely the problem. Online places advertise about $100 to fix it. If you could get a service manual, and are handy with a soldering iron (low power), you could do it yourself. You have to take the main board completely out. And if you DO fix it, lay a bead of epoxy around the sides and back of the jack, and let it set, so it doesn't happen again. Bounce these options against the price of another notebook.
Posted on Mar 04, 2009
I am recently upgrade win7 hp nx9110 audio output device not installed msg getting how to resolve
Ok this is kind of common with Windows 7. Although everyone thinks its new its really not just a fairly bug free OS. The HP models running Win7 actually are using the Vista or XP driver for audio. I just ran into that issue a few months ago when upgrading a Pavillian model.
Aug 13, 2010 | HP Compaq Business NX9110 Notebook
Compact nx 9110 screen does not light up can only see slightly
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 10, 2010 | HP Compaq nx9110 Notebook
When I turn the laptop on it powers up but there is a black screen. It's a compaq nx9110
Shut it down. Take the battery out. Unplug it. Leave the battery out then turn the computer back on. If you still have a black screen there is a hardware problem. If you have an external monitor connect it to the laptop and switch to show on external monitor. If you can see externaly then problem is cable or screen problem. If you can't see external picture then problem is most likely a chip on the motherboard. Video chip problem common on hp and compaq laptops.
Nov 07, 2009 | HP Compaq nx9110 Notebook
Cannot read cd's written on nx9110 on any other machine
Hi there , sound like it is a software problem , if you can only read it on that compaq , it may be the permision setting in the writing software , if you cannot change these setting you could try installing a different writing programme .
Dec 20, 2008 | HP Compaq Business NX9110 Notebook
Hi there, I have an hp compaq nx9110. I have used this to burn my photo's onto CD. I can however not read the cd's written on teh nx9110 on any other computer - not even DOS on the other machines sees the...
Try using (Ashampoo Burning Studio 6 FREE) this link below for all your burning needs .Also make sure to burn your photo's as data. This has work in all 4 of my computers & should be readable on all computer or laptops!
http://www.download.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Dec 20, 2008 | Computers & Internet
I have major probs with both my laptops...
Hi
I think your problem is with the battery ac/power voltage.
Make sure of the right voltage for your Laptops is selected on the Ac/power device you are using.
In other simple words, the high voltage causes the laptop to cut off as yours, and the soloution is that you try adjusting the voltage into a lower voltage.
I hope this works!
Nov 03, 2008 | HP Pavilion dv6000z Notebook
No Lights On But Fans On
I would start by using only 1 stick of RAM this sounds like symptom of a failing ram card or occasionally ram socket. The RAM is on the bottom of the laptop under the middle panel.
If you have 2 chips try each chip individually in each socket.
If it was turning itself off it was probably overheating - i see the fans gets clogged on this series all the time. You may want to blow it out with a can of compressed air.
Let us know if you need more help.
Oct 11, 2007 | HP Business Notebook NX9110 Notebook
No light is on but fans on
I would bet your system has been overheating - that's why it kept shutting off. Now it may have overheated and killed your CPU or mainboard. These laptops require quite a bit of disassembly to get at the CPU. You will probably have to take it to a repair shop for further work.
Oct 06, 2007 | HP Business Notebook NX9110 Notebook
Laptop Freez up only a few minutes after I turn it on.
You possibly have to many programs starting up when you turn on computer,try going into msconfig and turning off things that you don't need to start up.
Apr 26, 2007 | HP Compaq Business NX9110 Notebook
HP nx9110 Notebook Logo
395 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
