Question about Nikon D1X Digital Camera
Problems taking pictures on nikon d1x
I have a nikon d1x and have picked it up this morning to take pictures and suddenly i press the shutter release once and it trys to take about 20 photos shows an error message and wont actually capture a single shot, any ideas
  • meld1x Apr 19, 2009
    I have the saem problem! I just turned it on last night, going to take some photos and it says ERR and wont record any pictures what so ever, but the shutter goes off like 3 or 4 times.
    Problem Solver:
  • 15 Answers
There may be something wrong with the camera. Make sure it is set to Single Exposure setting and not Multiples. There should be a control on the top left to change this. Look for an "S". this is what you want. If that doesnt help, you may need to get it repaired.
Posted on Mar 10, 2009
  • Cause of the trouble, Shutter unit bad or spring broken anyways need to be replaced
My shutter release button on my Nikon P500 is not working. I press it half way and it will focus, but, when I press it full down it will not capture the picture. It started happening suddenly last week....
Try pressing the "Menu" button and disable "Active-D Lighting", also try setting the "Autofocus mode" to "Single". When the camera is off, press the shutter release and twist with the zoom know back and forth. Hopefully that fixes it! It worked for my P500 with the same problem.
Sep 25, 2013 | Nikon Cameras
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
Error in display
Press the shutter release again. Take out the battery and put it back in a while (1-2 min). Reset the camera with the reset button.
If this doesn't work, take it to the Nikon repair.
May 30, 2010 | Nikon D60 Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Good day, I have a Nikon D1X. The shutter button when slightly depressed should engage the AF in the lens. The lens is a Tamron. The camera Auto Focuses fine when you press either of the two AF buttons on...
You are correct, there is a setting. Press Monitor, then Menu to get to the menu; go to the thitd menu option (looks like a pencil), select option 4 (AF Activation) and set it to ON (Shutter/AF ON). This will solve your problem.
Dec 15, 2008 | Nikon D1X Digital Camera
NIKON D1X
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
Sep 13, 2008 | Nikon D70s Digital Camera
Nikon D40 shutter is not releasing err is releasing butten again but same prob
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
Jan 22, 2008 | Nikon D40x Digital Camera
Faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
Nov 01, 2007 | Nikon D40x Digital Camera
Open Questions:
Nikon D1X Digital Camera Logo
621 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
