Question about Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737
The front panel acts like there is no power.
A friend had a new control panel put on to operate the pool. It's not an Aqua Link, I think it's an Intella Touch. Everything works with the remote and at the panel from the service position except the heater.
The electrician says that he has power from the panel to the heater but the control panel will is dead on the heater. The power on light does not come on when you push the power button nor does anything else light up on it??
I am away from the property now, so I can't look at it but I know it's a gas heater and I believe that it's a Pentair 400. I remember that it has a touch pad type control panel on the front of the unit and there is a door that opens to expose the, board, wiring, etc.
Does anyone have any thoughts as to what the problem might be? The friend says that the heater worked prior to changing the controls so we have been guessing that the electrician may have wired something wrong or he may have fried the board in the heater?? Any thoughts please.
Obviously, we are going to have a second electrician look at the wiring but past that we would like some direction.
    Problem Solver:
  • 11 Answers
Typically the intellitouch controller is wired to the "fireman" switch on the heater. If the switch is not closed the heater will not turn on. If the heater was wired to the controller through the power supply rather than the fireman switch and the fireman switch is not bypassed at the heater the problem you describe would be created.
Posted on Aug 11, 2009
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
Jan 05, 2014 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Timer for pool does not stay on aqua pod
Check bateries on control panel. Next check the relay. Batteries in hand held too.
Dec 06, 2013 | Hayward Pool Products Aqua Pod
Cannot find reset button on aqua link rs system
top left of control panel there is a reset button make sure to write down all your auxillaries and programming because if you reset make sure to go into controller and clear memory also
Aug 13, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Communication error 2 means and requires what steps to correct?
try turning everything off then control then heater and hand held reboot system
Jun 30, 2012 | Goldline Pool & Spa
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
On my aqua link panel the service light is the only one lit up. I dont think it is producing chlorine
Thank you for posting your question here on Fixya.com.
The service light would mean that the control is running in service mode. You manually control each component when operating in service mode...it is made for technicians to be able to isolate various circuits when trying to troubleshoot the equipment.
Put the unit into auto mode and the equipment should go back to running normally according to the program.
For more on your control, check out the Jandy website on your product here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Nov 12, 2010 | Jandy AQUALINK RS TELELINK KIT
Pentair Mastertemp Pool & Spa Heater Dual Electronic Ignition 400,000 Btu Lonox Propane 460737 Logo
372 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
