Question about Intel D102GGC2 Motherboard
I have 2gb of ram.but system detected 1 gb of ram
I have 2gb of ram in my system now.but system detected 1 gb of ram. my mother board is Intel D102GGC2
  • Anonymous Mar 17, 2009
    My problem is also exactly same. i have 2gb of ram.but system detected 1 gb of ram" . In the bios setting it is showing only single channel. slot 0 is with 1 GB and slot 1 is showing as not installed.
  • 315 Answers
Make sure the board supports 2 gigs of ram, and make sure the board supports the type of ram you installed.
This info can be found either on the manufacturers website and/or the user manual that came with the board.
Posted on Mar 03, 2009
I want to upgrade my system ram size to system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
Upgrading ram
Well with this type of motherboard yes you can put 1gb into it however you can put up to 2gb on it and be just fine. Hope this helps you out.
Apr 11, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
u can easly use 2GB ram but due to low processing power u avoid havy programs run together.
check that cpu use not more then 80% regular it may get harm. so use 2GB ram without any worry.
just avoid havy programs run together.
Mar 03, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Upgrade ram
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
Feb 26, 2009 | Intel D101GGC Motherboard
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel D102GGC2 Motherboard Logo
222 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
