Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Wd63p dryer fan not working - Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • keith_graham Mar 02, 2009
    Found the problem ... apart from the thermal fuse o/c lead to the dryer motor had "come adrift" just at the tie wrap as it enters the loom.. All is well now ( that is after I replace the Thermal fuse) thanks for the sugestion. I also replaced the crimp connector to the dryer motor....
    Best regards
    Keith
  • Hotpoint Master
  • 3,463 Answers
Assuming it is heating, then the most likely cause of prob is faulty capacitor, that is the round cylindrical tube connected to dryer motor, or the fan motor could be seized, or a broken lead to motor.
Plese rate my solution.
Thanks.
Posted on Mar 02, 2009
No heat
There will be 2 possibilities. 1) Heater is defective 2) Dryer Fan is defective. If heater is working fine, plz replace replace the Fan.
Dec 03, 2013 | Dryers
My whitewestinghouse dryer trumble but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | Westinghouse Industrial Plus White-...
Dryer taking too long tp dry. Removed alot of lint buildup in exhaust system. Does this dryer have a fan and how can I check if it working?
The front of the dryer should be able to come off..maybe with clips maybe a couple screws...first you will need to pop up the top of the dryer with a flat blade screwdriver,then you can look down the front cover to see if there are clips or screws...remove screws/clips to remove front cover and gain access to fan and components...the fan is usually attached to the main motor that turns the drum. you should be able to run the dryer with the front cover removed to see if everything is working.
Dec 19, 2010 | Dryers
HOTPOINT WD63P IS LEAKING, WHERE DO I FIND THE FILTER TO CHECK IF IT NEEDS CLEANING??
Remove rear panel of washer, locate and remove large black hose from bottom of drum, remove and clean filter inside the hose.
Nov 22, 2010 | Washing Machines
I opened up and cleaned out the lint that had built up in my dryer. I attempted to clean out where the fan was. There was a clip that attached to a flat piece of metal inside the fan housing. I am trying...
unless your realy set on diging into the internal works of your dryer???? why not just leave it be? all you need to do is blow out any fluff in the fan,,
its that or strip down the hole thing and take out the motor???its a lot of work for nothing to gain realy
Jan 24, 2010 | Dryers
Everything is plugged in correctly but, dryer wont work
Check the exhaust fan at the bottom of the dryer, there is a possibility some my be lodged between the fan wall and the fan blades.
Dec 06, 2009 | Kenmore Dryers
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Fan is not working
exhaust fan on dryer is not working. I have cleaned the area at the bottom of the lint filter and cleaned the passage of the blower thoroughly.
Jun 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
119 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
