Question about Dell Inspiron 5100 Notebook
Two vertical Line developed in the monitor which is eye catching and had developed after runing a diagonistic test.
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
My CRT monitor which showing horizontal line
The CRT monitor has developed a fault in the vertical deflection circuit.
It is not worth getting it fixed, I suggest you put your money towards a LCD monitor.
Jun 27, 2011 | Computers & Internet
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
Pink and blue vertical lines through
It could just need the print heads cleaning or aligning
If you are not sure contact the shop you purchased your printer from it is under warrenty for 12 months
Apr 03, 2010 | Computers & Internet
Hi. I'm running two monitors off my HP notebook. a Planar and Dell, both 13". The Dell just got vertical lines and is mostly purple. what happened?
Disconnect the monitor from the back of the laptop . Check if the monitor is still purple in the self test feature check . Or there is a vertical line. If the color and the line is not there in the self test. Check the signal cable for any bent or broken pins. If the same is not the issue .
Check the video card drivers for problems.
Thanks
Proton
Feb 02, 2010 | Dell E173FP 17" LCD Monitor
Hi, About 6 months ago my screen developed a vertical dotted line down the screen. It has since developed two more - another blue and a red one. I'm not sure if this is a major issue or warning of...
hi if its an LCD monitor then its a fault of the screen itself if its under warranty then return it. If not You could try updating video drivers but i believe this is not the problem...proberly new monitor needed im afraid
Nov 01, 2008 | Computers & Internet
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Intermittent vertical lines
PANASONIC PV-C2540 Intermittant PROBLEM, picure is reduced to left to right vertical line. SEEMS TO WORK FINE WHEN SET HEATS UP?
Dec 22, 2007 | Televison & Video
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell Inspiron 5100 Notebook Logo
50 people viewed this question
Alun Cox
