Question about HP PSC 1315 All-In-One InkJet Printer
HP PSC 1400 all in one:
Can not change the print cartridge because it does not come in the center after the front cover is opened. Also the check paper light is blinking and is not accepting any paper.
  • rp_reek Mar 02, 2009
    Thanks for helping. Print cartridges do not come to center. Paper is pulled in jerks. It does not print at all. I shall take it to service center now. Keep helping.
  • 25 Answers
Some things to try...
Open the printer as though you were going to remove the cartridges.
Pull the paper that is in the tray out of the tray. Ensure you do not have too much paper for your particular tray to handle.
Look inside the printer to ensure there is no obvious paper jam. Close the printer. Give it a second or two to think....
Put the paper back into the paper tray. May just need a smaller pile of paper. If there is too much paper in your tray it will not go through the rollers properly.
If lights are still blinking after that however read any messages follow instructions if poss. Sometimes you just need to hit the enter button at this point to clear. Cartridges may align any point (hopefully).
If none of this works. Look for a "Toolbox" or something in your printer/scanner software on your computer that would enable you to send the align printer cartridges command from the software. That may align them as well.
I would be interested to know if this works. Good luck!
Posted on Mar 01, 2009
  • Jo-Anne Mar 02, 2009
    Hello again,
    Wondering if you have tried a re-install. Sometimes virus scanners or spy ware can remove the odd file that you actually need... I have gone through that where all of a sudden the printer starts to behave for no apparent reason.
    If you can run the "clean print cartridges" that may work as well.
Find the ink level hp 1400
Don't bother. Just keep on printing until the print isn't satisfactory and then change your cartridge or toner cartridge if it's a laser. They give you bogus answers to ink level to get you to buy new cartridges when you still can print with your current cartridge.
Oct 12, 2014 | HP PSC 1400
I cannot access the exsisting print cartridges to replace them on my hp psc 500 printer
Hi
Please note that the print cartridges can only be accessed when the printer is on.
  • Turn the printer on.
  • To access the cartridges,open the cartridge access door on the front of the printer and right above the paper output tray.
  • The cartridge carriage moves to the center so you can access it.
  • On the top of each cartridge is a latch,lift it.
  • You need to grasp the handle at the top of the cartridge pull forward and lift it up to remove.
Hope it helps.
Feb 22, 2012 | HP PSC 500 All-In-One Printer
HP PSC 1400 test page
Cartridge calibration pending in your printer. Put printed align page in to scanner and scan it.. ensure that mono & color cartridge should be in good healthy condition..
Dec 28, 2011 | HP PSC 1401 All-In-One Printer
Can you let me know where to locate the ink cartridge on the hp 1410,i cant find it to change it
Turn the printer on then open the front cover.The carriage with the cartridges will move to the center and you'll can change the cartridges.
Nov 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP 6110 check cartridge error won't clear with new cartridges. Anyone know how to fix this?
You could try this way first as its a lot quicker and easier than the official steps from HP:
Just hold down the ENTER button and then press the MENU button. There will be a series of 3 fast, high beeps. Then everything resists and is a-okay. Both problems go away.
OR The HP way as listed below:
The ink cartridge-related error messages may occur due to one
of the following reasons:
* The ink cartridge does not make a proper electrical contact
* The cartridge is bad or wrong
* The cartridge is remanufactured or refilled
To resolve the error, follow these steps:
Step one: Check the print cartridges and clean the cartridge contacts
Even if the cartridge is new, follow these steps to clean the print
cartridge contacts. Print cartridges have a substance on the contacts
to keep them from corroding during storage that may cause poor
electrical contact between the print carriage and the print cartridge.
1. Verify that the product is turned on.
NOTE: If the HP product is not turned on, you will not be able to
remove the print cartridges.
2. Open the top cover or the cartridge access door in one of the
following ways:
* Pull the control panel forward and then lift the top section
toward the back.
* Open the access door on the left or right of the unit. This door
may be located under the scanner glass lid on some flatbed
products.
* On many flatbed products, you raise the front center section of
the unit to access the print cartridges.
* Raise the cartridge access door on the front of the product.
3. After the print carriage stops moving, unplug the power cord. You
must unplug the power cord to prevent the print carriage from
moving.
4. Remove both print cartridges.
5. Verify that the part number on the cartridge is the correct part
number for the all-in-one and that the carriage is not blocked
preventing the cartridges from moving. Visit the following HP Web
site for a cartridge compatibility chart.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpa00586
6. The electrical contacts of the print cartridge are coated with a
thin layer of grease to protect them from oxidation. This grease
may inhibit the electrical connection and should be removed. Using
a cotton swab or cloth lightly moistened with distilled, filtered,
or bottled water, clean the electrical contacts of the cartridge.
This usually occurs with a new ink cartridge, but may also occur
with an older cartridge.
NOTE: When an all-in-one is used frequently for black and white
printing but infrequently for color printing (for example,
an all-in-one that is used primarily as a fax machine), the
color cartridge will still eventually fail and need to be
replaced. The pins in the print carriage can cause dents
on the contact points of the color cartridge over time
(usually between six and twelve months).
7. Wipe the contacts with a dry, cotton cloth.
8. Reinsert the cartridges and lock them in place.
9. Close the top cover or access door and plug in the power cord.
10. If the error persists, repeat these steps. If further cleaning
fails to resolve the error, proceed to "Step two: Clean the
print carriage contacts" section.
Step two: Clean the print carriage contacts
Have the following materials available to clean the print carriage
contacts:
* Cotton swabs or any soft material that will not come apart or leave
fibers (for example, a scrap piece of clean cotton cloth).
* Distilled, filtered, or bottled water (tap water may contain
contaminants that can damage the print cartridges).
CAUTION: Be careful not to get ink on hands or clothing.
To clean the cartridge contacts inside the product, follow these steps:
1. Turn on the unit.
2. Open the top cover or cartridge access door.
5. Using a cotton swab or cloth lightly moistened with distilled,
filtered, or bottled water, clean the electrical contacts of the
print carriage.
6. On models equipped with locking latches, lower the latches.
7. Wait five to ten minutes for the contacts to dry and then plug in
the power cord. The unit will begin to reinitialize. Wait until
the process is complete before proceeding.
8. Reinsert the print cartridges when prompted and then close the top
cover or access door.
9. If the message recurs, replace the print cartridge indicated by the
message.
* If you are using refilled or remanufactured cartridges or non-HP
cartridges, replace them with new HP cartridges. HP cannot
guarantee that refilled or non-HP cartridges will function
correctly in HP products.
10. If the problem still exists, replace both print cartridges. Since
the cartridges are electronically connected through the printed
circuit board, the cartridge not indicated in the message might be
the causing the failure.
If the issue still persists, please click on the link below and install
the firmware update:
ftp://ftp.hp.com/pub/softlib/software3/COL4415/oj-14700-3/HpAiOFWUpdate2_2.exe
NOTE: Clicking the link may give an error indicating it is
invalid. If this occurs, copy the portion of the address
on the remaining line(s) and paste it at the end of the
address showing in your browser until the complete address
is displayed in the Address box.
1. Download the file "HpAiOFWUpdate2_2.exe" to a local hard drive. Make
note where (in which folder) the file gets copied.
2. The hp all-in-one software for the OfficeJet 6100 series must be
installed on your PC before installing this firmware update. The
OfficeJet 6100 series must also be connected to your PC and turned on
before proceeding.
3. Locate the file "HpAiOFWUpdate2_2" on your hard drive and
double-click the file to install the firmware update.
This should resolve the issue. If you need further assistance, please
reply to this message and we will be happy to assist you further.
You may receive an e-mail survey regarding your e-mail support
experience. We would appreciate your feedback.
Please visit our Owner Services Web site for details on keeping your HP
and Compaq products up and running.
http://www.hp.com/home/ownerservices
I hope this helps
Mike
Jun 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1400 all in one:I can not change the print cartridge because it does not come in the center after the front cover is opened. Also the check paper light is blinking and is not accepting any paper.
i have had this problem with some of our old epson printers.
How i get round it, is to start the head cleanning mode on the printer and when the gead moves i quickly unplug the printer. if i am quick enougth i can then move the print head across manually.
Not ideal i know but it does work.
Ian
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
I can not print and the empty sign stays on my printer when still loaded A4 paper. I keep getting PRINT CARTRIDGE ERROR on my PC. My printer HP PSC 1400
is the Print Cartridge in right place? I think you should contact HP service. It can help to change the cartridge.
Jul 17, 2008 | HP Office Equipment & Supplies
Hp psc 1410, door open error
your door interlock is not makeing contac.chack the front door to see if it is lineing up whit the covers or see ifyou brook aneything inside the front cover whear you added toner.the interlock is in the front door of the michane also you can make sure all of the other doors is closed.
Mar 15, 2008 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 1410 all-in-one printer not printing
What is not working? The printer or the cartridge? If it's the cartridge, try this. fold a paper towel in 4ths, dampen it and place on a flat surface. Blot the cartridge several times on the towel. You should get blots of black with the black cart. and three colors with the color or photo cart. If not... replace. If the printer carriage just won't move and you're shure you have power.. time for a new printer.
Aug 27, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
