Question about FMI CPU Sensor Alarm Temperature Monitoring Device
Hello i just wanted to ask you guys something: i have a e8400 stock @ 3ghz and when i play games like crysis it seas that it's heated up to 45-48 degrees celsius and when i'm not playing any games i have around 35 slighty less slightly more to around 40 and when i turn my pc on i have to round 30 now is that good cuz i have a 140 mm fan infront that's spinning at round 4000 rpm even 5000 rpm
  • zer0_unleash Mar 01, 2009
    yeah the 140mm fan is a case fan
    thanks allot revskank i appreciate it
    i'm gonna buy 2 more 140mm fans (one from side and one from top) u think that'll help?
  • 203 Answers
The better the cooling you can add to the processor the cooler and better your cpu will be. the 140mm fan is a case fan, yes?
you will need to upgrade your cpu fan and heatsink.
CPUs on 45nm core are overall cooler than their predecessors on Core micro-architecture. However, the temperature different under 100% workload makes only 4-5 degrees. The thing is that Wolfdale processor core is smaller and features higher transistor density within a semiconductor die, which makes it a little harder for the heat flow to dissipate properly. That is why Wolfdale and Conroe heat up almost identically in idle mode. As for the relatively low temperature of AMD Athlon 64 X2 6400+, with twice as high TDP as that of Core 2 Duo actually, it can be explained by the not very best location of the on-die thermal sensor that is situated quite far from the hottest spots of the processor’s semiconductor die.
Posted on Mar 01, 2009
  • sean sutton
    sean sutton Mar 01, 2009
    your money would be better spent on a new heatsink and fan for your cpu. the 140mm case fan should put plenty of air into the case.
    i suggest you look into something like the Scythe Orochi CPU Cooler and stick another 140mm fan on the side of that.
XFX 6850 crashes
Had the same problem, video card went bad. Replaced with newer faster model.
Jun 12, 2013 | Computers & Internet
I can't access my media player when i play my
Try updating your media player. Get a higher version. tnx
Aug 18, 2011 | HEWLETT-PACKARD Intel Core 2 Duo E8400...
Registration code for crysis warhead
hi.
i put the key for you.
if it didn't work only ask for another:
KEY: D4W6-U6GQ-FA2E-XYQP-Q4ZQ
Jan 29, 2011 | Electronic Arts Crysis Warhead v1.1 Hotfix...
how can i get the registration code for crysis warhead........?
Plz help me.............
Sep 02, 2010 | Electronic Arts Crysis Warhead v1.1 Hotfix...
To install graphic card on Intel Motherboard D845GVSR
as a rule any Pentium 4 motherboard would not support a CPU let alone a video card that could play Crysis at any level that would be enjoyable. It's likely you either don't have a video card card expansion slot or that the one you have is AGP.
If you don't, sorry nothing you can do. If you have AGP you could in theory add a sufficiant card to meet the minimum spec and load the game but the store would have done you a disservice by selling it to you as your processor and RAM would barely alloww the game to load and even if a 1GB 9800 could be supported by you PC the performance your CPU could offer would leave the game lagging significantly on the physics side which would really mess up the game.
Frankly I work days in a retail computer store and have played crysis on several PCs, In my experience the minimum PC for "good" gameplay is a tri core AMD at least 2.1Ghz per CPU with 4GB of RAM and a 9600 512MB, and I have tried it on several machines.
My personal recommendation would be bare minimum:
Q6600 or AMD 8000 series Quad Core
4GB RAM
9800GT 512MB or ATI 4850 512MB
This will get a decent frame rate and support at least 1680 resolution, in gaming though, more is always better, frankly it would be cheaper to scrap that plan and by an Xbox with a copy of it's version of Crysis for under $400 unless you plan to play other PC only games in which case you can build what I recomended for around $1000US less if you already have a decent monitor or plan to hook up to a 120Hz LCD TV
Hope this helped,
Chris
Armor-IT
Apr 24, 2009 | Intel D845GVSR Motherboard
E8400 or Q6600
personally i have the q6600 which is a quad core processor, all the others you listed were dual core, personally i use alot of programs all at once which is good if you have a quad core, but just for general music, data, and streaming, the e8400 is probably better for you, its a 3ghz processor.
Mar 20, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
My PC freeze and restart while I play ANY strategy game
Have you reinstalled the specific games you are playing? If not, try that. If that does not work, write back.
Nov 21, 2008 | Computers & Internet
VIDEO MODE NOT SUPPORTED
wow uuh thats a good one to answer your problem did you get a new monitor 2 cause that could change it and if you hack into it you also might be able to fix it and what is crysis is like gears of war? send me an email at mathieu.1996@live.com
Oct 04, 2008 | Microsoft Halo 2 for Windows
FMI CPU Sensor Alarm Temperature Monitoring Device Logo
200 people viewed this question
Top FMI Computers & Internet Experts
David Payne
David Payne
Are you a FMI Computer and Internet Expert? Answer questions, earn points and help others
