Question about iLO (2 GB) MP3 Player
Hi my buddies, My transcend pen drive has got write protection virus inside it. I could not copy or delete any file in it. I have tried my level best by going to regedit and entered the value = 0 in all controlset. But still I have the same problem. Pls give me a good strong ways to remove it completely from my pen drive. Pls kindly help me my beloved great Indians. U can contact me to my mail - bala_stats@yahoo.in
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 04, 2010
Hi I have a transcend jetflash d33193 4Gb flash that won't format. It tells me the flash is write protected and i don't she any physical lock. i have tried every possible thing i know on it but it...
The message which you are facing while formatting your flash drive maybe be due to below reasons.
1) It could be due to virus. Try to scan your flash drive with your anti-virus and check.
2) Second reason would be when you connecting your flash drive it may include some autorun files which starts its own when you connect your flash drive and because that file is running it wont allow to be formatted, so try to delete all the files including in your flash drive and than try formatting.
or
There is right protect switch on many pen drives , a physical write protect switch which enables you to either allow writing on the disk or disallow writing on the disk.
All you need to do is toggle the right protect switch and you would be able to write files on your pen drive.
Please find an image below for more information.
Jun 08, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Am not able to copy nor delete files from my 8Gb transcend pen drive,the message display is ur drive is write protected,even it is not formated what shall i do.
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
or
use any low level formatting software....
Oct 25, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Remove Write protection from the Pen drive permanently
Hi Abhishek,
There is a samll tab in the which will have lock mark, move it to unlock.
That will remove the write proterction, still have issue replace the drive.
Thanks
Smith
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Remove Write Protection
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
May 18, 2009 | Kingston 4GB Secure Digital High Capacity...
Write protected
write protected i am not able to copy nor delete files from my 4gb transcend memory card
Apr 17, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Unable to open Pendrive
Your pen drive is infected by a virus/worm. I have two solutions for this -   > If you have WinRAR software, just open up the pen drive using this and delete "autorun.inf" from it.  OR  > Use any good antivirus software and scan your pen drive, and disinfect the pen drive from any virus/worms. Remove your pen drive, and insert it again. It'll work fine.
Dec 25, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
iLO (2 GB) MP3 Player Logo
53 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
