Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Error H-4 I had a fix at one time for error H-4 which was Alternate hitting Pink and Start button 2 times Enter 14 copies make 2-3 copies this is not working have another solution? h4 en xerox xd102
  • Xerox Master
  • 19,396 Answers
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Posted on Mar 01, 2009
Error message H 4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 08, 2008 | Xerox Office Equipment & Supplies
4 h error code on my xerox xc865
Jul 06, 2008 | Xerox Office Equipment & Supplies
Sharp copier model no. DM1505, will not copy
May 17, 2008 | Sharp Office Equipment & Supplies
Error code 4H
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp Printer 1551
Feb 25, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
Feb 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Flashing error code
Dec 20, 2007 | Toshiba e-Studio120 Copier
Toshiba e-studo120 H4 error code
This should do it.
Error
This should fix it
Dec 12, 2007 | Sharp AR-M162 All-In-One Laser Printer
Flashing 4-H error message
try this reset procedure. Most likely this will work.
Nov 29, 2007 | Sharp AL 1631 Copier
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
255 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
