Question about Peavey CH1 Speaker
I have a pair of peavey impulse 200`s one of the horns just crack`s up and I have to keep it lower than the other to stop it popping.Has it gone or is it fixable cheers.
    Problem Solver:
Hey, just picked up a pair of used peavey impulse 200p speakers .. one of the speakers is giving out this very loud high pictched hum (obviously not working). can anyone help or advice, thanks
Posted on Aug 17, 2010
I would get the horn replaced, as all you are doing is letting the cab get worse, i had the same problem with the 500's the diphgram had totaly exploded so for the sake of 95 quid its worth sorting it rather than paying for a new cab.
dj jackson
Posted on Dec 25, 2009
3 Suggested Answers
  • 17 Answers
SOURCE: peavey impulse 1015 horn cuts in and out
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Posted on Feb 04, 2009
SOURCE: Peavey Horn Drivers (compression drivers)
Did you sort your problem? I need 2 also, but seems quite easy to get 4ohm but 8 ohm a little harder. The woofer in the cab is 4ohm, cabinet is rated 4ohm so wondering wether to replace th 8ohm horn with a 4ohm diaphram.
Any thoughts?
Thanks.
Posted on Nov 13, 2012
I have a Peavey Impulse 200 speaker. The 12" speaker stopped working, but it and the circuit board look fine. What do I check now?
Disconnect the leads from the 12". Put a voltmeter across the speaker terminals and check for continuity. If it reads open, the speaker is dead.
May 16, 2017 | Peavey Music
Impulse-12d low end not working? fuse issue?
No..probably blew the 12 or the amp, could be a loose wire to speaker but.....
Nov 09, 2012 | Peavey Impulse-12d 1200 Watt Powered 12"...
Peavey xt22 horn not working
Across the diaphram you should be reading about 8 ohms. it sounds to me like it's blown.However,if you think it'ds thre crossove, take it out and send it to Peavey. They do good , fastwork.............................................................
Mar 23, 2017 | Music
Peavey SP 5 speaker has stopped working
Check the crossover network for cracked solder joints, specially pay attention to the female1/4 jacks as they are very tricky since they are switches also, you might be surprised...
Apr 29, 2012 | Peavey SP 5 Speaker PA Passive
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
I have peavey speakers Model #112H.Both horns went out,,i'm not sure what caused this. is there a component that i can replace,or just replace the horns completely?
If they are seperate speakers and both "horns" have gone it won't be a part common to both. The most common way of blowing both speakers is to have the amp too loud. The real cause is often connecting a high powered amp to low powered speakers.
As you will have to replace the horns if they have blown, disconect them from the circuit and apply a 1.5 volt battery to the terminals for a split second. (+to+ etc) It should 'pop' if it works. If it does it will be the crossover that has gone.
Feb 25, 2010 | Audio Players & Recorders
Any thoughts?
Thanks.
Nov 26, 2009 | Peavey Audio Players & Recorders
Peavey impulse 1015 horn cuts in and out
Jul 27, 2008 | Peavey CH1 Speaker
Hi, I need to replace the baskets on my peavey impulse 200 speakers. The baskets currently in them are 1268MR BW... (12 inch black widow) I am wondering if I can use differant baskets, due to the fact I'm...
Hi dieselbob25
Whats happening to the 1268? Oh and I couldnt find that model in the standard range available to the public at the peavey sites I checked here and Peavey
They may be a special edition for the Impulse boxes. Can you tell me what is happening to the speakers? Are they burning voice coils or what. May indicate another area of concern that is making them fail.
regards
Graeme
Apr 14, 2008 | Audio Players & Recorders
Peavey CH1 Speaker Logo
833 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
