Question about HP Pavilion dv9000z Notebook
MY LAPTOP SCREEN IS GONE BLANK...I CAN CONNECT IT TO AN EXTERNAL MONITOR BUT THE DISPLY ON THE LAPTOP SCREEN IS REALLY DIM...WAT SHOULD I DO? I TREID ADJUSTING SETTINGS ON THE LAPTOP BUT NOTHING WORKS..THE HP SERVICE CENTER IN GOA IS REALLY PATHETIC...THEY HAVEN EVEN SEEN MY MODEL BEFORE..DIRECTLY ASKED ME TO REPLACE THE ENTIRE TFT WHICH WIL COST ME ALMOST 15-20 THOUSAND BUCKS...WAT SHOULD I DO?
    Problem Solver:
  • 18 Answers
Hi, i have had the privilege of work on these particular series of HP Laptops. This may sound daft, but have you tried the brightness keys? If so you have a fault with the backlight which is caused by 1) a fault on the Mainboard 2) the inverter has blown (a small circuit board the regulates the voltage from main board to the lcd screen) 3) The backlight on the lcd screen has blown. You will need to determine where the fault lies before paying out large sums. You may want to get a diagnostic done by a Local laptop company. Hope this helps.
Posted on Mar 01, 2009
Laptop powers on disk light flickers & does not start up. The fan is working.Blank screen, when connected to external screen still no output
upon turning the computer on keep hitting the F8 key and see if a repair screen appears. If not the hard drive is gone or the disply is at fault
Aug 02, 2010 | Compaq Presario CQ60-220US PC Laptop
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
Hi my screen has gone blank on my laptop advent 5431 any ideas
I have gateway mx7118 and my screen went dim when power on. I connected to a external monitor and no pic on the monitor.
Could the problem be I need to replace the LCD invertor?
Nov 29, 2009 | Acer Aspire 4720 Notebook
My screen has just gone blank and i can't get it to come back up with any color or anything if i squint really hard i can barely see the windows log in but that's the extinct of it
have you tried connecting you laptop to an external monitor and check if get the same issue? If the issue does not appear in external monitor it means your laptop LCD has problems, but if it appears in the external monitor then your video card or motherboard has problems and needs replacement.
Oct 06, 2009 | Dell Latitude D600 Notebook
Hp tx 2000 screen does not show after boot up..wat can i use to get this to work.
Can you hear the hard drive spinning and does the computer appears to be running but you get a blank screen? If you look at the LCD screen at an acute angle and you see a dim image. then you have a backlight problem. To determine if you have a video card problem or a lcd screen problem, Connect an external monitor to your laptop and power the monitor up first and then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Get back to me with the results of these tests and any error messages etc. so I can advise you.
Jun 19, 2009 | HP Pavilion TX2000Z Notebook
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5315 Notebook
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
Lcd screen is on, but blank - nothing - no desktop comes up
Have you made sure it's not just switched over to external monitor? Check by holding the "Fn" button (usually at the bottom left of the keyboard) while pressing the key (often one of F1-F12) marked with different monitors. On mine this is F5. This may toggle it back if you have toggled it off by accident.
If it really is broken, I'd say $200 for a new one is a fair deal, at least if the computer itself is fairly up to date and powerfull.
Nov 07, 2007 | Toshiba Satellite A105-S4004 Notebook
Blank screen
1 Blank - absolutly or 2 stuff on the screen but dim and unlit? 1. - tube or inverter gone - workshop job 2 Ditto
May 30, 2007 | Compaq Armada M700 Notebook
HP Pavilion dv9000z Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
