Question about DeLonghi PAC T110P Portable Air Conditioner
Not Cooling At all.
The fan and even the compressor comes on but the air coming from the aircon is not cool. The Air con symbol is up but it is as if only the fan is on.
Any ideas?
    Problem Solver:
  • 16 Answers
Yeah same problem here it is most likely out of freon and lost its refrigerant charge, I have purchased a few of these to put in our offices and they all stopped working after 1 year (2 months after the warranty) :) how they make their money in repairs i guess.
However, I am searching for a local fix and once i get mine fixed ill return post to all of you what needs to be done.
Posted on Jun 26, 2010
  • 306 Answers
Sounds like you lost the refrigerant charge. No freon in other words. If you are sure the compressor is on then that is the only thing it could be.
Posted on Mar 02, 2009
I have a Rover 75is it normal for my engine fan to come on high when i turn on my airconditioner
typical set up is two fans in engine bay
engine cooling fan is separate
air con fan runs flat out when air con is on to cool condenser
Apr 28, 2017 | Rover Cars & Trucks
Cooling fan relay location for a 1992 corvet
the air con fan comes on with the air con switch. the engine cooling fan comes on when the engine temp. censer reaches operation temp. most times the air through the radiator when driving is enough to keep the censer cool and the fan not working if you stop at lights for any length of time it will come on.
Aug 15, 2014 | Cars & Trucks
WHY DOES MY RADIATOR FAN COMES ON ONLY WHEN MY AC IS ON ON MY 88 TOYOTA COROLLA
it is generally because the air con heat exchanger has to be cooled in order for your air con to work correctly and cool the interior of your car.
The air conditioning utilises a gas by the name of freon. This gas is pumped around the air con system by a compressor. The gas, going through the aircon cooler or heat exchanger, starts to cool down. Depending on the system layout, the gas is forced through a very small aperture situated after the cooler. It reverts to a liquid, passes through the matrix in the car, a fan blows the interior air of the car through the matrix. The fluid picks up the heat, and cooler air exits the matrix and, (hopefully) cools the interior of the car. This endless cycle is repeated as long as the air con is powered on.
Hope this brief description will suffice.
Jan 25, 2011 | 1988 Toyota Corolla 4 Door
Air conditioner isn't cooling the room
hi there,
insufficient cooling have several reason,most common factor is low freon charging due to service factor,defective thermostat control,dirty evaporator and condenser fin,try to check the current rating using ammeter clamp tester if the rated current read in tester below the rated current on tag(compressor)
you need to charge freon,if the fin and evaporator is dirty need to ve clean,if the thermostat is not functioning replace thermostat.
also consider the main defective if the aircon is running chck the compressor if it is running by touching the tip of screw driver to the top body of compressor you can feeel vibration,if compressor is not running yo don't have cooling effect only blowing of air.on repairing this this should be done by a certified aircon technician,have a nice day fix my rate,thank you very much.
May 14, 2010 | Fujitsu 24C1 Air Conditioner
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Noisy Aircon
Your compressor ismounted or rubber feet. If one or more of these rubber spacers is gone or loose you need to come up with some more. If these are still n place its possible that the compressor (which is mounted inside the black oval or round case) may have a broken spring. In this case its compressor time Im assuming your fan is ok as you say its only when the cooling is on. Only 4 things move on the AC 1= inside fan 2= outside fan 3= fan motor and 4=compressor& compressor moptor which are in 1 case.
If you need to know more add on more information but I believe if youve gave me all you can thhin of its something to do with the compressor.
OH yes FYI if the outer case of the compressor is round you have a rotary compressor and they arenatorious for being loud and viberating even when new. If you decide its inside the compressor Id suggest replace the whole thing cause the compressor viberation causes tyhe copper lines to become hard and can crack eaisly.  Hope this helps. PLEASE Grade me ACCORDINGLY and good luck.
Mar 03, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Air conditioning compressor
the missing part could be the cover... its ok , not cooling very well could be:-
1, aircon fan not working
2, system need to be service
3, need to add air-con gas
for air-con works only in full position.... need to change the switch.. its faulty.
Oct 19, 2008 | 1988 Daihatsu Charade
Air conditioner constantly shuts off
Are you saying that you have plugged the aircon into an extension lead then into a socket in the wall and that the smoke was coming from the extension lead part. If so I would suggest checking all your plug in connections and chenge the extension lead. A quick way to check the compressor is a cause is to put the aircon to fan only and see if it fails to trip out the circuit breaker, then put it back onto cooling and see if it trips (if it does on cooling then its a good possibility). Most aircons have a three to five minute time delay for starting the compressor to protect against power fluctuations (ie power cuts). Hope this s of some help.
Sep 11, 2007 | Frigidaire FAC107P1A Wall/Window Air...
DeLonghi PAC T110P Portable Air Conditioner Logo
252 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
