Question about Hotpoint WMA48 Front Load Washer
Does the hotpoint wma48 need a hot water supply connected?
I heard that most new washing machines dont need a hot water connection.
  • vijay321 Mar 02, 2009
    many thanks
  • 150 Answers
This is true. Just check if the machine has one or two water connections. If it has two you need a hot connection also
Posted on Mar 01, 2009
  • ANDY PLUMB Mar 01, 2009
    if there are two water connection points then ideally yes. The machine will work if you only connect a cold supply but will need to use the heater in the machine to reach wash temperature. This will mean longer wash cycles.
    Yes it does
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Where is the filter on the machine
Unplug the washing machine and turn off the water.
Open the small trap door next to the drain hose connection on the back of the washer to gain access to the filter.
Take care.
Jan 11, 2011 | Hotpoint WMA48 Front Load Washer
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
HotPoint WF215 Washing Machine I have a Hotpoint WF215 washing machine but it seems as though it is not pulling through the hot water even on the hottest cycle. Ihave checked the hoses to the hot...
Hot and cold water supply is each controlled by an electrically operated solenoid valve which is operated either direct from the programmer on older machines or as more electronics and then computers were increasingly part of washers, by the electronics.
I suggest you visually check the wiring and then check the hot water valve solenoid for continuity. If it is open circuit replace it but if ok check it is receiving mains voltage when the machine should be hot filling - if so the valve could be stuck or blocked and if no voltage it probably needs a new circuit board or programmer.
Nov 10, 2017 | Washing Machines
Manual WMA48
To get the information you require you need to type in your browser bar the following. hotpoint user manuals
In the list on the left click on manuals-user guides-handbooks-hotpoint service
Then in the search box type in your model number of washer, and download instructions, as req'd.
PleaseThankyou. rate my solution to your query.
Jan 27, 2009 | Hotpoint WMA48 Front Load Washer
Hotpoint wma48 wahing machine will not pump out water
It does have a filter but its in an awkward place. first remove the access panel at back of machine. To the right you will see the pump. Follow the pipe from pump to drum and you will notice that its much bigger where it meets the drum. remove pipe at this end and its there.best to take machine outside first.
Nov 14, 2008 | Hotpoint WMA48 Front Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
need to know a little more really but here goes, if you remove the top and the drive belt is still on then it will be as straight forward as the motor brushes at fault they will need replacing as this is a common fault on these machines. hope this helps
Mar 06, 2007 | Hotpoint WMA48 Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
