Question about HP 19BII Calculator
Battery 12 Volt or 1,5 Volt? - HP 19BII Calculator
  • HP Master
  • 7,993 Answers
Non rechargeable (AAA, AA, D, C) batteries are 1,5 V.
Rechargeable batteries of the above types are 1,2 V.
But it will not make a difference using them, except maybe that the rechargeable ones drain sooner than the alkaline ones.
Hope it helps
Posted on Aug 20, 2009
  • k24674 Dec 25, 2009
    The HP 19 BII requires small 1.5 V batteries. Equivalent model numbers are MN9100, E90, LR1. The Duracell model is labeled MEDICAL
Batteries are 1.5 volt.
Posted on Aug 18, 2009
Charging system failed. Why is new alternator output ranging between 11 1/2 and 12 1/2 volts?
11 1/2 to 12 1/2 is not charging . That's less then battery state of charge , Battery stat of charge should be 12.6 volts , when charging with a volt meter you should see 13.1 to 14.1 volt at the battery posts . Is there a battery symbol lit on your instrument cluster ? Is there battery B+ voltage at the wires hooked to the alternator How to Test an Alternator
Feb 18, 2016 | 2001 Kia Spectra
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
What the differential betwen LC and UB type battery, for example LC-X1220P and UB12220. thanks.
Specs Volt 12 Amps 22 Length 7.13 Width 3 Height 6.57 Terminals NB Weight (17.5) Manufacturer Universal Power Model # UB12220 Universal 12 Volt 22AH Battery UB12220 Universal 12 Volt 22AH Battery
Specs Volt 12 Amps 20 Length 7.126 Width 2.992 Height 6.575 Terminals NB Weight (14.56) Manufacturer Panasonic Model # LC-X1220P Panasonic 12 Volt 20AH BatteryLC-X1220P Panasonic 12 Volt 20AH Battery
Dec 28, 2010 | Panasonic LC-X1220AP - UPS battery - 1 x...
Harley davidson batteries are they 6 or 12 volt?
Hello, my name is Ben. Your battery is 12 volts. Here are the complete battery specs : 12-volt, 19 amp-hour, 270 cca.
Oct 11, 2010 | 2001 Harley Davidson FXST Softail Standard
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
24 volt charging problems .2 12 volt batteries 1 battery 16volts and the other about 9-10 volts
A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
Aug 19, 2008 | Toyota Land Cruiser Cars & Trucks
HP 19BII Calculator Logo
116 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
