Question about Panasonic NN-S541 Microwave Oven
When microwave wss turned on, there was no heat but smoke
When microwave wss turned on, there was no heat but lots of smoke & an electrical smell. Since there was no heat, what was burning to cause the smoke?
  • William Miller
    William Miller May 11, 2010
    It may have come from grease on or behind the waveguide cover, or due to a defective high voltage transformer or inverter, depending on the model number.
    What's yours?
  • Panasonic Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Microwave does not "heat" and smells when turned on.
calling the company will be the best suggestion because if the smell is like burning plastic, it will be a problem electrically
Mar 21, 2016 | Microwave Ovens
I put a mug of water in the microwave, left the room. Came back, and the room was filled with a burning electrical/plastic smell, no visible smoke. Now, the microwave completely powers off after 1 second...
Since there was no smoke, it's not a transformer. It's most likely a high voltage diode or magnetron. The magnetron would be over heating and opening a thermal cut out mounted to or near it.
Oct 19, 2013 | Samsung SMH9187ST Microwave Oven
Kenmore microwave 80082 sparking from an inside panel
If your positive it is not arcing behind the waveguide cover I would think it has to be in the control area. You will have to turn off power to the unit and remove the control panel and look to see if you can find any burn marks or soot, to indicate where your problem may be. I have found burnt connectors at the relays or even possibly burnt wires to the door switches. Careful! the capacitor on these can hold a charge for a long time and can shock you pretty good. Only work on something like this with the power to it off and the capacitor discharged. Microwaves do not come through the little round holes those are typically an RF screen to prevent microwaves from getting through. A lot of times that is where the cavity lamp shines through.
Aug 14, 2017 | Microwave Ovens
Not heating. Electrical burn smell.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][[\\[]
May 19, 2010 | GE JVM1440 Microwave Oven
Limited heat power
It sounds like the transformer is shorting out on you but is not completely shorted.It will be shorting out on the output side of the transformer.this will give you a lower output level,and will cause the microwaves to be weaker.(less turns of wire in the secondary of the transformer).The short will probably get worse.Simply replacing the transformer should cure the microwave.
Jun 23, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
I would like to know how to clean the inside of my microwave,the wrong cup was put in,and it caught on fire ,and I can't get smoke stain out. Thank you,Molly Dickerson
The smoke stain is almost impossible to remove as smoke tends to get in the pigment of the paint.
If there's a burn smell, you can try simmering a lemon juice and water mixture for several minutes in the microwave. You can also set a plate of charcoal briquettes inside and leave the door closed overnight (DON'T turn the microwave on - just let it sit). Keep the charcoal inside when not using the microwave and it will absorb a lot of the odor.
Jul 17, 2008 | GE Microwave Ovens
Maytag microwave mmv1153aaw
my guess would be the wave cover. sometimes they smoke and makes sparking sounds. does it still heat food?...if it does, then its not the magnetron.
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Panasonic NN-S541 Microwave Oven Logo
197 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
