Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx will not start
We have power to the machine and the programme time is indicated, when we select a wash. Everything looks as it should do. Pressing the start button changes the indicator to wash but the machine doesn't start and after about one minute the wash indicator starts to flash. The door lock doesn't engage when we press start and the door can be opened at any time.
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
Posted on Mar 06, 2009
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE DOOR THEN TRIED TO PUT IT ON A PROGRAMME AND IT CAME UP -0- AND IT WOULD NOT START NO TIMES WAS COMING UP WHEN I TURNED THE DIAL ONTO A PROGRAMME.PRESSED...
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Oct 04, 2009 | Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Jul 31, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
362 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
