Question about AEG B1180-4 Electric Single Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again after a period of time
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
I have a Competence B 6139-4-m electric oven. the door does not close properly, have tried cleaning it as intruction manual suggests, the heat escaping from the oven has scorched my cupboards
the fault is unlikely to be the actual oven unit so therefore in order of least expense the things to check are:- the door seal being complete, the hinges not having been forced, the door not being buckled, self adhesive universal seals are available online from *spares etc. Hinges are easy to remove from the cooker and then can be unscrewed from the door and replaced. if it's the door I would have to say that's less likely to be available for a sensible price.
Feb 05, 2013 | AEG B1180-4 Electric Single Oven
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
How do i turn off the auto timer on an oven, i do not use the timer and by accident it has been moved and now i can not get my oven to come on, i have tried turning the timing switched but that did not...
Sometimes you have to depress the timer switch button and then turn it, normally you have to select whether you want Manual or Timed cooking i do not think you can disable it altogether although it will depend what make of oven you have.
Dec 21, 2009 | Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Aeg b4101 single oven ,three years od
Sounds like a faulty thermostat.You will need a new one
Nov 07, 2008 | AEG B1180-4 Electric Single Oven
Clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Jul 13, 2008 | AEG B1180-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
753 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
