Question about Whirlpool GT4185SK Microwave Oven
Need new light bulb
Info on back of oven
MODEL NO.ER-7800EW 66200743
240v. 5.6A.
Single Phase A.C.50 hz.
Output frequency :245oMHz
Made in JapaTOSIBA CORPORATIT)KYO JAPAN
Other info on back:
Canada Patent 795986
France Patent 1.477.092
Other Nos.
E489372001
E189375401
  • Whirlpool Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 02, 2009
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
What is the actual power wattage? on the back it says single phase 1200 w and out output is 800 w.I dont understand the difference
1200 watts in to operate the appliance then 800 watts power output emitted in microwaves for cooking.
Sep 16, 2015 | Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Find a new glass tray small size Emerson MW7300W suffix C
Try www.ebay.com Type make and model of microwave oven, and go through the list.
Jul 11, 2012 | Emerson MW8168B Microwave Oven
I have purchased Faema E98 President from Dubai. I was told that this model works on both single phase and 3 phase. I brought the electrician to fit the single phase but he didn't understand the single...
This may be useful;
http://www.home-barista.com/espresso-machines/electrical-trouble-on-faema-e98-2-president-t6943.html
There is no dificulty with single or 3 phase wiring.
Try a qualified electrician!
Mar 07, 2011 | Microwave Ovens
I purchase a microwave which is 240v 50z but in my country we usually use 230v 60hz, can i use AVR to solve my problem?
Hi. An AVR (auto voltage regulator) will not change the freqs from 50 Hz to 60 Hz. An AVR only changes voltage. The frequency in is the same frequency out.
Having said that.... I don't think your going to damage your unit as long as you don't run it for long periods time. I live in the tropics and use 4 different AVRs myself. I have had both 50z and 60 hz electronics and appliances running fine on 60 Hz for the last 7 years. Your call! Hopefully this was useful information.
Jan 14, 2010 | Microwave Ovens
50 hertz microwave to send in Philippines which frequency is50-60
u.s. is all 60 hz. not sure in the phillipines,the only issue is it will cook slower due to the lower input frequency, it shows no electronic control board in the diagram, sometimes a different freq. can throw electronics off i.e. the clock would run slower and not keep accurate time on 50 hz. as it would on 60hz.
Oct 11, 2009 | Sharp R-510HW Microwave Oven
Voltage difference
Actually the voltage is the same, it's the frequency which is different. Running 60 cycle equippment on 50 cycle current is usually no problem. Most noticeble difference is that motor rpm will drop (by about 15%).
Charlie
Aug 20, 2009 | Microwave Ovens
Panasonic S588BA MHz
As far as I know, all of them run at 2450MHz (aka 2.45GHz).
If you're also concerned with power output in watts, I didn't find much on this model, and you may have to visit panasonic.com for contact info.
Mar 09, 2008 | Panasonic NN-S588BA Microwave Oven
Whirlpool GT4185SK Microwave Oven Logo
74 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
