Question about Pioneer AVIC-N3 Car DVD Player
Mono amp hook-up
I got all my power leads ran to the amp and the amp turns on. I just need to know where to attach my low frequency patch cords that lead from my amp.
  • 33 Answers
You need to run the RCAs to the rca output of your stereo or if you have a stock stereo you will need to run it high level or buy an line output converter
Posted on Mar 02, 2009
How do I wire a kicker mono amp for my subwoofer
You'll need to take the low frequency from the crossover to drive the sub woofer amp otherwise you'll get full range out of the mono amp which will reduce the low frequencies presented to the sub spesker.
Sep 23, 2014 | Car Audio & Video
Can I hook up my roku device to this tv If so what kind of cable do I need?
On the back of the TV/VCR unit there is an input for audio & video plugs. These will accept a composite video signal and mono audio signal. I'm not sure if newer roku has these outputs as they are low def only signals. The roku would need to have have red, white & yellow sockets. (Old Roku's had these....) Yellow is video, red and white are L & R audio. Use a y adapter to merge red & white together, and use a standard RCA patch cord to connect the roku composite outputs to the TV VCR inputs.
May 01, 2014 | GE 19TVR62 19 in. TV/VCR Combo
I am wireing an amp in my car and i have the cd player hard wired to car how do i hook up my remote wire for my amp??? lilwayne1777@yahoo.com
The cd player should have a blue or a bluew/whitestripe wire that would be the turn on wire to use. If those colors don't exist, use the the power antenna wire. If you don't have any of those you can always use a switched twelve volt lead from the car like an accessory lead from the car.
Aug 20, 2010 | Scosche Industries EFX Amplifier Wiring...
How do you hook your compacitor to your amp
take your main power/ground leads,put them on the capacitors terminals,then take how ever many feet of wire needed to go to your amp,put the ground on ground and power on power.
Jul 10, 2010 | Scosche Industries EFX Amplifier Wiring...
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
Car audio
low grade patch cables, or connection secquence incorrect, monoblock amps require a heavy input load, it should be the last one in config-
the mono will pull alot of amps from the source pos. thus ripping off the other amps in lineuse good patch cables to feed the multi first, then the mono....
Sep 13, 2009 | Kicker KX600.1 Car Audio Amplifier
I cant get power to the amp, everything is hooked up right, i replaced the power cord fuse... what else could be wrong,...??? the green led light is off and i tested to volts on the remote terminal and it...
Check in this order:
  1. Battery connection
  2. Fuse at battery
  3. Ground wire at vehicle
  4. Bat. and ground at amp
  5. Remote turn on lead should read 12v
If you have no power at the turn on lead pull deck and see if it cam disconnected, should be blue w/ white strip.
Jun 01, 2009 | Kicker SX650.1 650W Mono-Block Amplifier...
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Pioneer AVIC-N3 Car DVD Player Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
