Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Laptop unable to start but only displays post screen
I have a Toshiba Setellite Laptop that is failing to start but only displays the post screen. When I punch in F2 button to enter into setup, I get the messege saying "check system then press F1.
When I press F1, setup window will come.
If I go out of setup window, it still shows post screen but no booting. what should I do to resolve this?
  • dmdzoole Mar 05, 2009
    Hey man, you have just rescued me because I didn't know what to do with the crashed Laptop. Thanks for the help. You are relly a friend in need!
  • 1,223 Answers
Ur OS has corrupted two reasons for that
1. due to virus, malware spyware, etc
2. Hard Disk is getting weak wants replacement
solution first try to re install the OS if u find it difficult to do so then my friend ur hard disk needs replacement
factory reset procedure
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls rate me FIXYA if i fixed ur problem
Posted on Mar 03, 2009
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Laptop screen has a 1" wide, white bar.
What is a screencard? I think they mean display driver, try uninstalling Display Adapter and then reinstalling sometime fixes problems.
Apr 08, 2014 | Toshiba Satellite M65-S909 Laptop...
IF you are using windoows 8 machine. Note that P2GO supports Miracast and so does Win8,
1. Connect both P2GO and laptop to same network. Access charms menu and find P2GO Devices .
2. Choose project and then duplicate screen.
If doesnt work. Open Screen Resolution from context menu ( right click on Desktop ) and make sure screen is listed.
If using earlier windows versions (excluding XP)
1. UNINSTALL P2Go driver and restart computer
2. Install driver
3 connect device
Feb 25, 2014 | Toshiba Satellite P755S5215 PC Notebook
Alison the first step you need to take is to try to prove whether it is just the laptop display that has failed or whether it is more serious than that.
If you have access to a separate computer monitor, i.e. on a second desktop computer, then try connecting this to your Toshiba laptop and see if you get any information posted on the monitor when booting the laptop.
If you do see the normal boot / start-up messages being posted, then you have shown that the laptop display is at fault and you will probably need to take the laptop to a repair shop.
If you don't see any boot / start-up messages with the external display connected, then you have a more fundamental problem with the laptop.
Check to make sure that you do not have any CD / DVD / Diskette or USB devices connected to the laptop, that it might try to boot from. Listen for any beeps from the computer speaker when you initially turn on the laptop, and check for any LED lights flashing to show that there is any internal disk activity, and that the power LED is lit
If you are seeing LED lights, then there could be a problem with the Operating system (Windows XP?).
If you are not seeing any LED lights, then again, it sounds likely that the laptop system board may have failed - you would need to take it to a repair shop for further investigation.
You could try removing the laptop battery and then connecting the power supply to see if that makes a difference - I have seen laptops that would not boot with a failed battery in place, but which started Ok with it removed.
Jan 01, 2012 | Toshiba Computers & Internet
I have the toshiba setellite 2430 laptop i want sound driver for so pls give me or provide the link
i am hanzilla the solution for your problem is given below
choose the link at your wish
both links are for(Toshiba Satellite 2430 PC Notebook)
[] q=free+toshiba+satellite+2430+sound+driver+&sourceid=ie7&
Jan 25, 2011 | Toshiba Satellite 2430 Notebook
I have a Toshiba Latop (P105 S6217) (SN=17122387W) (Mod=PSPADU 00W00S). In recent days, I am getting very thin lines across my display screen. Could this possibly been the Mother Board going bad. The...
You possibly have a LCD screen failing, but to be 100% sure, you should hook your laptop to an external monitor, and see if the display is good . Any desktop monitor will work. If your display is good, you know your LCD on your laptop is failing, and if it is the same display as your laptop, you know you have a video chip problem on your laptop motherboard.
Sep 21, 2010 | Toshiba Computers & Internet
Driver for a Toshiba laptop Model no. Setellite A100 PSAARL 03S004 is needed. From where and how to get?
hi sir
my laptop giving slow response in operation ,i didnt get drive from toshiba web side ,my laptop no is a25-s307 plese help me...
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba setellite black out
Sounds like the back light on the screen isn't working properly which will need to be replaced if this is the case. Check for a very dark image on the screen when it is booting up in a well lit room, if you can see the computer start up then it is the back light.
Jun 25, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
385 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
