Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
The fridge is 4 the freezer is 4 the problem is fridge warm
The freezer is o.k. but the fridge is not cooling
i checked the grill it is opened
  • gerffin Mar 09, 2009
    I have the same problem and I can't figure it out. I have checked the damper and it is operating normal, great air flow in the freezer section. I cleaned the evap. coils, fan and condensor area but still have no air flow in fridge area.
  • 410 Answers
Can you hear a fan motor blowing or feel air blowing in the freezer section? I'm thinking this fan has quit running and is not distributing air to the refrig section. If this fan is running then check that you can feel air blowing out of the vent at the top of the refig section if not check that the damper is open. you can do this by removing the grill on the vent (it just snaps out) as warm as the refrig is this should be wide open.
The fan os the most likely and most commonly seen problem for me. the part number is 12002744 and is approx 40 dollars. this is a fairly easy fix if your mechanicly inclined. if you call a service company you will be looking at 150-250 depending on the company.
If you have any further questions leave me a comment here thanks Peyton
Posted on Mar 01, 2009
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
Tip
Lights on one side fridge not cooling.
mine fridge Viking VCBB363L Bottom Freezer Refrigerator.
Took a cell phone camera in video mode and put it in the fridge to see if the light was going out when the door was closed.
Turns out. it wasn't.
This causes the lghts on the left to go out. However, the light on the right stays on and warms up the fridge.
Solution.
Top section air grill. 5 1/4 hex screws.. remove the grill you'll notice door's light switch on right side. a steel spring attached to the switch. When fridge's hinge arm closes the arm pushes on this guy and pushing in the switch button and shuts off the lights.
you can move this with your finger.
In my case switch has a little purple button.
take two pair of 3 in needle nose pliers and CAREFULLY hold center of spring and bend the end nearest you to the left.
You don't have to go crazy Just a bit.
then get you camera ready and check out your work.
Results after you've succeded, replace your parts, and notice after 10 minutes the lights all come on, the alrms stop and the fridge cools normally.
and you saved 200.00
on Jun 24, 2008 | Viking VCBB363L Bottom Freezer...
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Fridge not getting cold
Check the condenser grille on the back is clean and warm to the touch. It should cool down towards the bottom and the drier cooler still. If it's cold, suspect short of refrigerant. If it's hot, move the fridge away from the wall to help it cool down.
Aug 06, 2012 | Refrigerators
I have a Baumatic fridge/freezer the fridge is not cold even on maximum setting the model number is BRB2713 please can you suggest what the problem might be
First check the simple things. Check to condenser grill and make sure the air flow is not blocked by lint, etc. And then make sure that nothing is blocking the cooling tubes between the freezer and refrigerator. I think the Baumatic has a fan pulling the cold air up from the freezer compartment into the fridge, if that isn't working, the freezer would be fine, but the fridge would be to warm.
Jun 03, 2011 | Baumatic BR22 8A Bottom Freezer...
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
129 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
