Question about IBM NetVista M42 PC Desktop
How much capacity hard disk can be installed to a p3 motherboard
I have gigabyte GA-6IWFE (P-III) MOTHERBOARD WHAT MAXIMUM CAPACITY HARD DISK COULD BE INSTALLED WITH THIS BOARD.
    Problem Solver:
  • 14 Answers
Any size as far as i no
Posted on Mar 01, 2009
Can 500gd hard disk be connected to gigabyte 945gcm-s2l?
Yes you can, there won't be any problem install 500GB hard disk on your motherboard. It is recommended to use SATA type Hard Disk Drive instead of the old IDE/ATA.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 07, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Hard disk support, How much? 250GB Or less than
Your motherboard has two SATA connectors, this means you can use any capacity of drive, and also that you can use two drives. So your motherboard has no limit to the size of the hard disk, you can accommodate as large a hard drive as you want.
Jul 03, 2011 | Gigabyte GA-8VM800M Motherboard
Need max memory and hard drive size for Gigabyte GA-5AA motherbrd
Max Supported of your motherboard memory is 768 MB SDRAM DIMM(100,133,166,200 MHZ). You can find the full specifications here:
http://latam.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1439
Thanks for using Fixya
Jul 28, 2010 | Gigabyte GA-5AA Motherboard
How much is the maximum capacity of hard disk in p4vmm2 motherboard
Motherboards do not have hard disks but you can attach hard disks to them. Most motherboards allow you to connect several hard disks of various sizes. Most home computers only have one hard disk.
Open your computer back up look for the hard disk(s).
The capacity of the hard disk is usually on its label.
If not, you can look it up by the manufacturer and model name on Google to determine the capacity.
Depending on the size of the disk, 1 or more GB of the total capacity will be inaccessable because it is used to format the disk. (e.g. Windows might only "see" 28GB of 30GB disk.)
If this helps please vote for my solution.
Dec 02, 2009 | Acer Computers & Internet
What is the reccomended highest capacity for installing a HDD in a K8M800-8237 motherboard?
ahita, Hard drive capacity is not limited by motherboard types, but by operating systems.
As long as you're using Windows XP, Windows Vista, or Windows 7, you should have no problems using any size hard drive.
Nov 04, 2009 | Gigabyte GA-K8VM800M Motherboard
Which is the maximum capacity of hard disk for this board? Gigabyte GA-7IXE4
As such you can alway increase limit by any means.
But the limit of this board it 2TB maximum on IDE.
But if you need more then attach USb drive or SCSI for the same
May 15, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Hdd installation
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Dec 05, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
IBM NetVista M42 PC Desktop Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
