Question about Panasonic SC-HT70 System
My sa-ht70 wont go above 0db on the volume control,it used to but wont now. Any help?
  • 336 Answers
Check and lower the speaker levels. Then see what the max is on the volume control.
Posted on Mar 01, 2009
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
I need a remote for as-ht70home theatre
Here is one on the Bay
PANASONIC Remote Control for SC HT70 SC HT65 SA HT70 SA HT65 Free Shipping
Couldn't find factory new available. Best bet may be a universal.
Jan 06, 2015 | Audio Players & Recorders
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
Can Panasonic saht70 play blueray disc
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
God bless you
Nov 25, 2013 | Panasonic Sa-ht70 Home Theater Receiver 5...
Panasonic sa ht70 surround sound instructions
I just tried this with another set of speakers and unfortunately since the iPad does not have left center or right speaker gain you will have to settle for the sound from one side level. unless you can figure out a way to splice all the speaker's configuration to a audio jack then you will have to settle for ear phone sound quality.
Nov 25, 2013 | Audio Players & Recorders
I have skandia universal remote and need code for soniq 42in plasma tv
I have a BASE DV-4304 DVD Player and i need the code for my Skandia Universal Remote. Please Help.
Dec 31, 2009 | Televison & Video
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
To convert my SA-HT70 to multi-region
to unlock you dvd player just press play button and turn off the device at the same time .
Jul 04, 2008 | Audio Players & Recorders
VOLUME CONTROL
Try to increase the speaker levels through setup. I had the same problem and I increased the speaker level from 0dB to +10dB, and seems like it is better now. Let me know how you make out.
Nov 29, 2007 | Onkyo HT-SR800 System
Won't play
This DVD home theater system has a defect that is not being addressed by panasonic. The Optical lens and or DVD Motor will give out after 2 to 3 years for no reason. It will start saying "No Disc" and will not play any DVD or CD. To repair this it will cost you £100.00 to £135.00 to repair. An authorized panasonic repair company told me that if I repair this it will last me up to 3 years and I would have to fix the DVD Player again. The dvd player model number is SA-HT70 and the number for the system is SC-HT70. The SA-HT70 is the dvd player that is not reliable. Without warning in 2 to 3 years you will have to repair the optical lens or dvd motor which will not be covered by Panasonic.
Feb 12, 2007 | Panasonic SC-HT70 System
Panasonic SC-HT70 System Logo
427 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
