Question about Bosch 24 in. SGV53E03 Built-In Dishwasher
How to adjust the legs
Adjust the legs
  • 3 Answers
Remove any plinth in front of the base of the machine. In the middle of the base you should see a black screw head with arrows either side. This screw adjusts the height of the machine at the back - clockwise = up and visa versa. The two feet at the front screw in or out of the base moulding to raise or lower the machine. Check that these have not been secured by screws through the front moulding. If so, slacken or remove. NOTE: make sure if the machine is already installed that you have loosened the screws which secure the machine at the top to the underside of your worktop.
Posted on Mar 01, 2009
Leveling kenmore elite front loader
  • Place the level on the top of the washing machineicon1.png to see if it is level. Make sure you test it side to side and front to back.
    Pull the washing machine away from any walls if you have to make an adjustment to the legs.
  • Lift the washericon1.png and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
  • Loosen the nut that secures the legicon1.png with the wrench.
  • Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
  • Remove the block of wood from under the washer and recheck the machine with the level.
  • Raise or lower the leg if additional adjustments are needed.
  • Tighten the nut on the leg with the wrench when the machine is level.
  • Repeat the process for each leg that needs to be adjusted.
  • Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
    Richard Roth
  • Nov 13, 2012 | Kenmore Elite 45986 Front Load Washer
    This is a joke. have a simple question & have to pay. just wanted to know how to adjust back leg on a whirlpool thin twin.
    the back legs tend to get stuck after sitting in one place for so long.use a screwdriver and free both legs so both are down that should free it up so it will pivot and the back legs will automically adjust and level theirself (you will need to screw in/out front legs to adjust them)
    Aug 22, 2011 | Whirlpool Washing Machines
    Moved my thin twin to clean & the back leg on the
    I have a 1973 whirlpool washer. I am trying to adjust the back legs on it. It appears to have a spring loaded bar between each of the back legs. The back legs are not adjustable and look to be self...
    Disconnect ac/cord,hoses and drain pipe, lay machine down on front side. Inspect the self-leveling bar ***'y and spray liberally with WD-40 if rusty and/or stuck.
    Feb 22, 2011 | Whirlpool Washing Machines
    My matag washin machine worked perfectly on a cement floor we moved it into a tile floor and it shakes all over the place it tried to level it but it still shakes
    You can adjust at least two of the legs o the washer. Lengthen the leg till all four are securely on the floor. It should be easy to adjust with the washer tilted on two legs. It's not uncommon to need to adjust the legs from one floor to another.
    Nov 01, 2010 | Maytag Legacy Series Top Load Washer
    The machine is brand new and shakes violently when on spin cycle
    Hi. Most likely the leving legs are not adjusted properly. You can check this by pushing on the sides for you uint from all four corners indivisually. It the unit teeters on 2 legs then the legs are improperly adjusted. The easiest way to adjust them is to push on the cormer that causes any movement and rotate the adjusting leg downward. If the unit is already high then lower the longer legs intil the unit sops moving when you press on the TOP corners of the unit. Good luck. I think you can have this one solved easily.
    Jan 10, 2010 | Washing Machines
    Kenmore 700 series top load washer problem
    This machine has self adjusting legs in the rear. Tilt the machine forward and see if you can hear the spring loaded legs adjust in the back if not they may need some lubrication and some help. tap on legs with hammer gently and they will usually release. Front legs have screw adjustments and very important locking nut which 99 out of 100 installers wont use. Thank you
    May 29, 2009 | Washing Machines
    Spins off balance
    Hello kel_lyn_eve,
    Because your washing machine is so heavy, when it's not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine.
    Your washing machine has adjustable, front leveling legs with a lock nut. You adjust the leg to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
    Some machines have adjustable leveling legs in the rear also, and you can adjust them in the same way. Keep the machine as close to the floor as possible--the lower it is, the less likely it is to vibrate.
    Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper.
    Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Oct 12, 2008 | Washing Machines
    The back legs are usually not adjustable. Adjust the front legs & lock them with the lock nuts, at the lowest level, that is the machine tilts towards the front. Adjust further if there is any shake when you try with your hands.
    You could also check to see if any springs or shocks have become loose. Refer manual.
    Mar 30, 2008 | Washing Machines
    Bosch 24 in. SGV53E03 Built-In Dishwasher Logo
    1,861 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
