Question about IBM NetVista M42 PC Desktop
Installing xp with fast speed
It practically takes 1 hr. to load xp on new blanck hard disk by conventional cd. is there any technique with that a hardware engineer could install it fast.
  • 565 Answers
The speed depends how fast is you hdd 5400 or 7200 and is it 8mb or 16mb speed overload. also it depends how much u have memory
Posted on Mar 01, 2009
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
My acer laptop is automatically restarting plz suggest me how to repair i want to install new XP OS
There are two reasons for computer to get restarted
1 operating system issue
2 hardware issue
to identify the problem
leave your acer laptop on bios screen if it is restarting in the bios screen which means it is a hardware issue however if it doesn't restart in bios it is an operating system issue
To fix xp incert the xp disk, boot the cmputer from cd, in the first screen press enter, then F8 for license agreement and then letter R to repair, the process will take approx. 1 hr and the computer will start working normal
Sep 21, 2011 | Acer Computers & Internet
I tried to install windows xp on sata hard disk but it couldn't find any hard disk in installation.in bios i can see the hard drisk that it shows RAID hard disk 60gb.my msi model is ms-7113 ver 1.what...
get to BIOs ..locate the hard disk ..and change the setting from the ACHI ..to sata like ide..or compatible ..Or ..use use a usb ..or a floppy ..to enter a raid driver for it ..when you install it ..If you pay attention ..when you run the installation of the xp ..Just after starting to load files ..(soon after press any key to boot from cd ) ..it says to press f 6 for to load 3rd party driver ..press it ..and use some kinda memory device ..that will be see..and load teh driver ..and will work )
Or ..just disable the sata raid ..for the hard disk ..and it will be seen after that when you load the operation system ..If it is a newish model ..it will not be affected ..only old models feel the difference in speed between the modes..
Aug 14, 2011 | Intel Motherboard
When I am starting my Lenovo G550,Model Name-20023 it restart with blue scrren. I am trying to start it in safe mode but same problems appears. Then I am trying to format the system with windows XP-2 but...
If you get a blue screen then you have a piece of hardware loose inside your lappy or could be a loose cable on the hard drive or cd/dvd rom, since lappy's are very hard to take apart it's best to take it to a shop to get fixed sorry.
Jul 08, 2011 | Computers & Internet
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
My western digital hard drive woun't boot up to window it say Disk Boot failure Insert system disk and press enter that all it say, internet hacker really did hurt my hard dive, all i need is a disk with...
system files are corrupt....re-format and install OS....
i your are using WinXP my website can be of some help...
www.sureshayyar.110mb.com
also do this...if ur data in the PC is not critical and u dont mind loosing them..
do a low level format...
http://www.4shared.com/file/gTU7Zdj3/boot-cd-iso.html
get this application from my shared drive and burn a CD...on another machine.....in this laptop ensure boot seq is set to CDrom as 1st boot drive in BIOS...insert the CD in the laptop....with the software u downloaded....power off and power on again....let it boot from the CD... let the DOS application start....use an application called KILLDISK on the left side of the DOS application that comes up...follow onscreen inst....ur disk will be as god as new....have patience...a 20 GB disk will take aprox 1 hr to become clean....a 100 GB disk will take more than 5 hrs...u can then install Windows after formating and partition...
all the best
Sep 26, 2010 | Western Digital Computers & Internet
Hello there: really just looking for some solid advise this hp52w w has the original xp operating system in it with sp2 installed works ok but it gets so slow on the starting windows screen it takes...
Hello Mike, Hi, may I suggest you try first to defrag your hard drive, Im sure when you power on your PC, the hard disk led keeps on blinking, your hard drive may have developed bad tracks and sectors, this slow moving process tends to go forever.
Defragmenting and checkdisk can find faults and bad sectors and tracks that slows down the performance of your PC.
Reformatting should be done if your defragmentation procedure fails to speed up your PC.
Try to run an antivirus program, which may help speed up your PC by detecting viruses, that tends to load forever, or slow down the booting process.
Nov 24, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Dear Sir I have a problem with ACER EXTENSA-5210 Laptop , I cant format my hard disk and windows instolation plz what can i format my laptop
of course you can format your laptop's hard disk. but you cannot do it while you are running windows. to format your hard disk and install a fresh copy of windows, you need to have 1) Windows XP CD Installer and 2) a valid cd key to complete your installation
How?
Load the CD Installer to your CD/dvd drive and restart your windows. When booting, your laptop recognize a bootable CD so it boots from there and not from your hard disk. Just follow the on-screen instructions to proceed.
Oct 15, 2009 | Computers & Internet
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
IBM NetVista M42 PC Desktop Logo
54 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
