Left side of screen is amazingly perfect color sharpness and tint, but the right side in the middle and top are dull not nearly as vivid as the left side......I've checked power board and t-con and flex ribbons seeing nothing out of character......WHAT IS MY ISSUE SOMEONE PLEASE HELP
SOURCE: Yellow Tint over picture...
do you have a speaker next to it? you need to de-gauls it try taking a magnet touch the screen and while you pull it a way from the screen slowly make a circular motion out wards and you should see the colors swirl keep doing this until it is clearer. This happens to tv and computer monitors all the time you can also check to see it their is a reset feature in your menu sometime this will degauss the screen for you. hope this helps.
SOURCE: I amd wondering on the Power Board #BN96-03775A on
Usually if they will plug in it is right, but if you have one of those that fit all, then I wouldn't be afraid to start with the first since if it doesn't work, you can always try the second. One may give a better picture than the other, that you might compare with.
SOURCE: Samsung LN52A550 - 2 1/2 years old - I have
It could either be the T-con(AKA LCD controller) or its the LCD panel. It cannot be anything else. So you should give the T-con a try and chances are it can fix the set.
SOURCE: Split screen, right side perfect left side garbage
Just visit this site for details. I can't type in all the details by this window. The site name is "Electro-help". Search for it in internet. It is an electronic equipments' repair help site in English language. All about faults to DLP TVs, and its recitciations are described here in detail.
http://img526.imageshack.us/img5
http://img837.imageshack.us/img837/117/c...
http://img195.imageshack.us/img195/8476/...
http://img689.imageshack.us/img689/9500/...
[URLhttp://imageshack.us/photo/my-images/94/...][IMGhttp://img94.imageshack.us/img94/4991/ca...[/IMG][/URL] Uploaded with [URLhttp://imageshack.us]ImageShack.us[/URL]
took pictures with red, green, and blue.......also regular screen images to show where the color is missing
also done factory reset's in regular menu as well as service menu....with no changes!
also done firware upgrade through samsund website.....did not help
found the t-con board was making a clicking noise and my picture went all black . I can still see backlight though....FAULTY T-CON BOARD!!!!!!!!
