Question about Acer Aspire 3680 Laptop
Delete bios password
How do i delete a bios password so that i can use my computer
  • 20 Answers
  • There is battery on your main board or a key named 'clear-cs'. You can hit this key for cleaning the password or if your main board does not have such a key you can easily 'put put' the battry and then (for both ways) turn on your PC.
  • If you are comfortable with messing around with the inside of a computer, then you can do it yourself - otherwise get a computer technician or the local computer whiz to do it. Anyways here goes. After you open up the case, look for the battery on the motherboard, and carefuly remove it from its socket. Then locate the CMOS jumper (it looks like a small plastic thingy on 2 pins with 1 pin beside it, within a 1" of the battery). If you're having trouble looking for it, look in the motherboard manual. After you have found it, carefuly pull straight up on it, and place it on the 2-3 pins(it was on the 1-2 pins). With the battery removed and the jumper moved, turn the computer on, and check to see if you can get into the bios. If you are able to, turn the computer off, put the jumper back on pins 1-2, and put the battery back in. Lastly put the case together and you are done.
  • The other answers listed are correct in that removing the battery you can clear your password, but there are some other things that should be said. When removing this battery not only will it remove the password, but it will also reset all BIOS settings to fail-safe defaults so if you have modified settings in the past you may have to modify them again. Also when removing the battery you may also be required to unplug your computer or at least turn off your power supply.
  • There are less intrusive ways: Do a google search for "Default Bios passwords" or "Bios password cracker". Bios passwords are very insecure, and they put default passwords in at the factory that will work no matter what. It sure beats taking the battery out.
  • Simply remove the computer case and locate the battery on the motherboard. With the computer off remove the battery for 5-10 minutes seconds and replace the battery. Fix the cover back on and power on the computer.
  • Some of these answers will break your PC for Good and you will definitely have to bring it to someone with knowledge. Have you tried simple passwords like ADMIN, or nothing(blank) or the manufacturer's name or TECH or something so simple you will cry when you find it! PS most of the time when you reset a BIOS you must manually input all the settings by hand, good luck with that if haven't written them down.
  • These are some of the default Bios passwords used with different Bios's, give them a try first. AMI, Award, bios, setup, cmos, concat, AMI_SW (case sensitive), AMI!SW/, AMI?SW/, j262
  • The second answer which is resetting the jumper is fine, but do it without taking your battery off from the motherboard. Taking the battery off from motherboard not only erases your passoword but also resets bios. So just perform the jumper part.
Posted on Mar 01, 2009
Reset bios Toshiba Satellite C655-sp600l
Password on Hard Drive: you bricked the computer.
Password on Bios: you need to remove the battery (motherboard battery) for 30 seconds and place it again.
Password of Windows: You need to get a software tool designed to recover or reset/delete your Windows password
Jan 27, 2015 | Toshiba Satellite Computers & Internet
Bios and, or, windows passwords
Google search for "Hirens.BootCD.15.2"
Its free and with it you can boot your computer and view, delete, or change any password on your computer without turning a single screw on your machine, even repair windows problems that are normally a dead issue.
Your bios administrator password, boot password or even HDD password,
Also all your windows or Linux log on or boot passwords
I am currently uploading the cd to my filesanywhere account and will make it downloadable for you if needed, just ask
on Mar 26, 2015 | Acer Unlock Bios Password:Aspire Zg5 Aoa...
Flashing bios
if you know how to take out the BIOS battery on your computer, this may help you.
1. Once system battery has been removed, reboot your computer.
2. System will ask the password upon reboot. Just hit enter,
password will be deleted.
Mar 27, 2014 | Samsung N Computers & Internet
Remove password from hardrive in bios
Before your computer loads your operating system, it starts by running the BIOS program, which is extremely important because of its various options.
You can even set a password on your hard drive so that nobody can use your laptop computer without your password.
Once you put in the password into your hard drive, you can only remove it by accessing the BIOS system and deleting the password completely from the memory of your computer.
Save all of your important files on an external hard drive or similar storage device.
This is a precaution to avoid losing all of your files when making changes to the BIOS.
Then, restart your computer.
Wait for your computer's operating system to ask you to access the BIOS menu.
This may be at different times, depending on the manufacturer of your computer.
It can ask you when the manufacturer's logo comes up, or on a separate screen indicating for you to click the "F2" button on your keyboard to start.
Access the BIOS menu by clicking the key or combination of keys that you are informed to click. This information can be found in your computer's manual, but it changes between different companies.
Commonly used keys for this process are "F10", "F2" and "Delete."
Go to the BIOS option that contains your hard disk drive password.
The option that will lead you to this password varies immensely due to different laptop models, but it may appear as something such as "Advanced" or "Security."
Look for the option for changing the password, which should say "User Password," and then click "Enter." Put in the existing password and then click "Enter."
Do not enter any password into the blank fields asking you to enter a new password, and this will remove the password.
Exit the menu by clicking "Save and Exit." Click "Enter."
Mar 17, 2014 | Computers & Internet
Need Bios Password
I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Mar 07, 2014 | Toshiba Satellite A135-S2266 Notebook
Re: TOSHIBA company have a problem with Toshiba Satellite laptop model A135-S2246, is enabled in the BIOS password, can you help me to delete from the computer. You can contact me at add....
If you don't know the password to the BIOS - you're screwed. There's absolutely no way to recover it back. You may take it to a computer repair shop or Toshiba Repair place and let them reset the BIOS Password.
Dec 22, 2010 | Toshiba Satellite A135-S2246 Notebook
I want to break my bios password
You may reset the BIOS password by removing the CMOS Battery and re-inserting it.
The CMOS Battery will store the Computer Date, Time, BIOS Password and much more information.
Removing and re-inserting the CMOS Battery will delete the BIOS Password.
Please perform the above steps to reset the BIOS password.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 21, 2010 | Computers & Internet
How to break d bios password
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 11, 2010 | Acer Computers & Internet
How i can move delete bios password on laptop hp nx 63 25or can i get original password
it is not possible to delete the BIOS password set by the user. However, you can try remove and reseating the CMOS battery of the computer. This will delete the BIOS password sometimes. You can refer the manual below to remove reseat the CMOS battery.
Refer page no:116
i hope this helps u. If not, then the only option is to contact HP or any local computer service center
May 21, 2010 | HP Compaq nx6325 Notebook
My computer has a password in the BIOS Setting. i forgot it
Do you know what the password is? If so, enter the bios and change it. When asked for a new password, just hit enter. If it asks a second time to confirm the password, just hit enter again.
Good luck
Mar 17, 2009 | Dell Inspiron 8600 Notebook
Acer Aspire 3680 Laptop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
