Question about Garmin Fishfinder 160 GPS Receiver
Garmin Fishfinder 160 will not display bottom contours and does not display depth continuously.
  • 3 more comments
  • robca54 Mar 15, 2009
    The transducer is of course below the waterline and is 3/8 of an inch below the aluminium hull and 20 inches to one side of the propeller.
  • robca54 Mar 16, 2009
    Thank-you for the advice, I will lower the transducer and try in on manual settings. It seems to make sense, I did get a bottom image at one time when it was on manual settings and the gain was set quite high/ low -5???
    Will not be able to try it out until the weekend, but will keep you informed, thanks again.
  • robca54 Apr 07, 2009
    I lowered the transducer so that it was about 3/4" below the bottom of the boat and it worked very well with all settings on manual, I will also switch it over to fresh water even though I fish only in the ocean.
    Thank-you everyone for your help and advice, it has been most helpful.
  • Dean
    Dean May 11, 2010
    Where do you have the transducer positioned in relation to the hull , and the height of the trasnducer... is it below the waterline?
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
Posted on Apr 07, 2009
  • 285 Answers
If you can drop it even a little further to about an inch below hull line and try it, that would be a good test. I guess the only other thing to check is that the transducer is close to horizontal in its positioning, and then check your gain/sensitivity settings. Try remove the settings from any auto modes they may be set on and manually set gain/sensitivity to a higher value. Often when you set a fishfinder to Auto mode you automatically lose up to 30% of the raw data that comes from the transducer!
If all of the above have been done and still no success it might be worth contacting Garmin or sourcing a replacement unit/transducer. That is about all I can think of at this stage.
Posted on Mar 15, 2009
  • Dean
    Dean Mar 16, 2009
    Yes try lowering when you can and let me know.
    I have used quite a few fishfinders and using "Auto" settings is quite a big no-no if you really want your sounder to perform in its best possible manner.
    Also, I would seriously recommend grabbing https://www.amazon.com/dp/1865131032?tag...">this book
    It is an awesome book showing you how to set up fishfinders properly and how to interpret what you see on the screen.
  • Dean
    Dean Apr 07, 2009
    Great to hear you have it working well now after lowering it!
    Please rate my solution on FixYa!
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Garmin 300c fishfinder will go from correct depth to 0.0 ft while traveling.Have to turn it off and restart. It is on Hurricane deck boat 198. It is located between engine and leveling tabs.
My experience as a user is that turbulence around the transducer can cause mine to flash and the depth to remain static.Is your fault affected by speed? Sounds to me that you have a faulty connection causing the transducer to "not register". I'd check connections and also the integrity of the transducer. Hope that helps...
Best of luck
May 28, 2014 | Garmin FISHFINDER 300C NIC ()
My Garmin 400c dual beam transducer keeps freezing up, it will flash "0" depth and then go to a "updating software" screen.
check your battery voltage. Low voltage can cause errors end prevent the sonar from starting up. If charging the battery doesn't work then contact garmin for a replacement.
Nov 30, 2010 | Garmin Fishfinder 400c With Dual Beam...
Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Jul 08, 2010 | Garmin Fishfinder 90
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Hummingbird Fishfinder model 535
The Depth & temp come from two different sensors. Check your coax cable to the transducer (the lager oval piece), the connector, and the transducer for cracks /breaks in insulation. Good luck.
Oct 25, 2008 | Boating
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Garmin Fishfinder 160 GPS Receiver Logo
962 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
