Question about GoVideo R6750 DVD Recorder
Dvd player won't read dvd
I have had my Go Video R6750 for three years(it was a gift) and I am just now trying to use it. It has been in the box all this time and I have set it up, but every dvd I put in it to play I get a reading that no dvd is in player. What am I supposed to do.
    Problem Solver:
  • 15 Answers
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
How do you record from my tv and what channels will I get?
Has this ever worked?
When you mention channel I assume you mean the channel on your TV set. Normally an S-Video input will be an aux input channel and not a numbered station on your set. How do you select the player chanel/ input when you watch the DVD?
Is the arial connected to the PVR then to the TV or direct to the TV It needs t pass through the PVR.
Jun 24, 2014 | GoVideo R6750 DVD Recorder
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
Where do i find users guide for R6750 Dvd Vcr recorder by GO Video
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. Here is the manual / guide:
http://micromatikal.dlinkddns.com:8000/cust/R6750.pdf
Sep 06, 2010 | GoVideo Go Video DVD/VCR Combo
I received a cobydvd224 as a gift but don't know how to connect to my cable box-pls help
There may be several ways, depends on your TV. Your TV may have: HDMI, Component, Standard Video, or RF in. You need to match one of those connections to the DVD players available connects. For example... if you have a newer HD TV your cable may be connected to the component input of the TV if there's an HDMI input on the TV and an HDMI output on the DVD Player, simply connect them together and put the TV in HDMI mode.
I know it's confusing sometimes, but read the book and you should be able to figure it out. Let me know if I can help more...
Geno
Dec 06, 2009 | Coby DVD-224 DVD Player
Can't hook up video recorder looking for the owners manual
you can find the owners manual at retrevo.com. it's a free pdf download. good luck
Oct 14, 2009 | GoVideo R6750 DVD Recorder
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
Cyber Home DVD Lens Needed Urgently
Hello Sir,
Unfortunately the lens for this player will cost more then a whole new player. These tiny players are designed to be thrown away after they are worn out. Your best plan is to throw it away and purchase a new player.
Sorry I could not help you further
Thanks for reading!
Apr 17, 2008 | Cyberhome CH-DVD 300 DVD Player
GoVideo R6750 DVD Recorder Logo
70 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
