Question about HP OfficeJet 7410 All-In-One InkJet Printer
Change Scan to Memory Resolution
Hi
I have a HP7410 and would like to change the scan resolution from 200dpi to higher when scanning to the memory card on the machine.
How do I do this?
Thanks
Mark
Paper is jamming while trying to print - i want to see if any paper is jammed but cannot open to see in there.
Posted on Mar 01, 2009
The Memory Full on display panel comes on after scaning about 23 pages. Please advise. Thank you!
Omlobatto,
If that is the only data in the memory, then the scan settings could be overzealous. Try checking the resolution for scans and see if it is set above 200dpi, which is plenty of detail for a fax. Anything higher could make files too large. Also, see if the fax is keeping all docs it sends in memory, and purge them if needed, then change applicable settings. If you could give model # and manufacturer of the fax, I can assist in this if needed.
Bruce
May 04, 2011 | Office Equipment & Supplies
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
Jun 01, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Brother MFC9440CN scan resolution
Yes you do this from the application that yu are using to do the scan. Chooese the setup or preferences tab for the scanner in the app and you should get a list of available optical resolutions from 75dpi, 100 dpi, 200dpi, 300dpi, 600dpi, 1200dpi upwards.
The optical resolution is 1200 x 2400dpi max and interpolated (from software) is 19200 x 19200 dpi.
Nov 11, 2009 | Apple ~:~ BROTHER INTERNATIONAL CORP ~:~...
I want to increase the size of the small drawings i do from my epson 1250 scanner to my canon 1800ip to a4 printout size is this possible.
You have to scan the pictures with a higher resolution to be able to print them in a larger format with acceptable quality.
If your default scanning setting is, say, 150dpi resolution, and you want the picture to be enlarged twofold, then you have to increase the resolution to 300dpi. If you have 300dpi now, increase it to 600dpi.
Some scanner utilities do a fully automatic scan - then you have to find the automatic scan settings and change the default resolution. Or better yet, find an option for a non-automatic scan, where you are presented with various options after the preview scan has been done. There you can usually set the desired size, resolution, improve contrast, sharpness etc.
Generally, the higher the scanning resolution, the more detail you have on the picture, and the higher magnification you can obtain when printing without quality loss.
But there's a catch - a picture in higher resolution produces a bigger file on disk - the file size grows faster then the resolution - a two times bigger picture will be four times bigger on disk. So you have to make sensible choice.
Nov 06, 2009 | Canon Office Equipment & Supplies
How to change the default scan resolution on M20i?
You need to go to the printers webpage from your Web Browser http://192.168.1.100 or something like that. Then, go into Properties tab, and then the Services Dropdown. Under that, go into Email Settings and then Email Setup. Change your DPI to as high as 600dpi, then scroll to the bottom and hit save. You'll be prompted for a password which is either Admin / 1111 or 11111 / x-admin
May 01, 2009 | Xerox WorkCentre M20i All-In-One Laser...
MY RICOH 2020D PRINTER, IS VERY SLOW AND IT DOES NOT SCANNED AT 20PPM, PLUS THE FAX MEMORY ONLY HOLDS UP 40 PAGES, WHAT CAN I DO?
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" ...is either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
I am having problems with scanning my pictures in the copying area . I tried reinstalling the hp psc2400 officejet 5510 and nothing is happening. Please help me I need my printer. Thank you Yvette
try lowering the scan resolution ie to 150 dpi to save memory, if this works then add another memory module to your pc if higher resolution is required
Oct 31, 2008 | HP Office Equipment & Supplies
Hi, Remote Fax Error being displayed
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
