Are you sure it agitates or it sounds like it,you could have a broken motor coupling and i would check this first anyway,also check to see if any oil is around the coupling area a little ways back on the trans.if you do find oil on your hand you have a bad trans.just rub your hand over the bottom of the trans. right behind the motor and coupling.watch video
http://www.youtube.com/watch?v=9K1KHEogf3c
hope this helps,also when you set it to spin if you hear the motor running and hear like a grinding noise this is the coupling.
SOURCE: Whirlpool Washer LSR8233EQO
either motor faulty or if mtor is running then the flexibla coupling between the gearbox and the motor is faulty. Regards Advisor
SOURCE: will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: Washer will fill with water and drain but won't
Your lid switch is fine. Because it will pump out and wash. That must be a broken drive coupling. More here Plenty more here
Rate it or hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
