Question about Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk)
Maximum MB or GB of graphic memory supported by Celeron d 325?
My mother board is Intel® Desktop Board D845GVFN
I have 2gb ram
and my processor speed is 2.53 GHz
What is best graphic suitable for me? i.e Maximum MB or GB of graphic memory supported by Celeron d 325?
  • 239 Answers
You can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
Posted on Mar 02, 2009
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I want to upgrade my system ram size to system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Can i use 768MB of graphic card in Celeron d 325
You can use 768MB GPU if your mobo alows it. It dosent have anything at al to do with the PSU.
Good luck
Mar 04, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Vista HELP
with the 64 mb graphics card i dont think that u can run VISTA if u want to run Premium version u need to get a higher graphics card atleast 128 Mb or above and for 1 gb graphics card pls check the manual of ur card first b4 buying it bcoz ur mother board may not support it but its a rare case when this happens but pls check b4 buying or let me know with the exact brand and model u r going to buy i will check it for u
pls rate me fixya if i have answered ur question
Mar 03, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
u can easly use 2GB ram but due to low processing power u avoid havy programs run together.
check that cpu use not more then 80% regular it may get harm. so use 2GB ram without any worry.
just avoid havy programs run together.
BEST graphic caed for celeron d 325
u may invest in an nvidia 8600 gt 512 gpu which may support dx10 price around 3500
HELP with with Intel celeron d 325
Phew, k3! A ton of questions and even more confusion going on here!
Firstly (love that non-word), your Motherboard accepts DDR Ram. Unfortunately, DDR2 will not be compatible. Won't work. Sorry. It does accept up to 2gb of DDR Ram, though.
Second, for Graphic Card slots, it has 3 x PCI slots (NOT PCI-Express), which are great for G-Cards. Maximum amount of memory won;t be affected by your MB, but by your processor and ram. As long as it has a PCI slot for a PCI card, you'll be good. Just be sure to turn off integrated graphics in BIOS settings.
Thirdly, good luck. Opening up the side of your PC can be daunting at first. Ensure you either have the patience to learn before you touch or have the money to continue learning as you go. >.o
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk) Logo
170 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
