IP conflict on Print server
SOURCE: lost connexion to windows server
Check if it's online in the Server, o a scan and print. The check the sharing status - is it shared ?
SOURCE: connected ir3300 to network. Can ping static ip
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
SOURCE: HI , I have a
the settings you are asking are for the network printing, simple stand alone usb printing does not need these settings, first of all go to "ADMINISTRATOR MODE" then in this mode, Select 5th option which is "NETWORK SETTING" in this option enter your desired tcp/ip and DNS addresses.
SOURCE: MY Ricoh Aficio 2550 Printer I
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
