Question about HP Compaq nc6000 Notebook
Laptop screen in 4 sections
Hi, I was wondering if you could help me. I have had my laptop for 1 and a half year now, but yet I really fear that it may already ne broken... everytime I turn it on, it appears in 4 screens. The main screen is simply cut in 4 and what should appear on the normal screen, appears in all 4 small sections. At the begining, restarting it was enough to solve the problem, but now I can't ever get e normal screen again...
Thanks for you help
  • 33 Answers
It could be your settings on the monitor but I think it would be a good idear if you took it to someone that knows about computers or even ring tme manufacturer
Posted on Jun 15, 2009
Hi, My LGX130's screen keeps to resists it self to resolution 800x480 and half of the screen doesn't work, so i turn it off for one to two days and it comes normal, and BTW when the half scree
I was going to suggest that you may be using a bad driver/firmware update for your monitor, so I surfed LG's laptop/support section but found nothing for drivers so your best bet is to call them really, unless someone else around here can make a suggestion.
Dec 07, 2012 | LG X130 Netbook
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Is it worth to buy part for screen for laptop or it can be fix? Plms with laptop is when i put laptop down n screen dropped half n top half is blanks n bottom half is blurring can see half of it.... help
The screen replacement is not cheap, hook a spare monitor to the video output usually on the back, if okay! the LCD screen is bad and must be replaced, if symptom is the same for both, it is the Video Graphics Card that is the problem normally built into the motherboard, If the laptop is a few years old I would opt to replace it.
Mar 13, 2012 | Samsung Computers & Internet
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
Hi.. I have a dell studio 1558 laptop how to get pound sign on this keyboard..Can anyone help me out with this?
1.Hold shift and then press 4
2. You can also try to use on-screen keyboard found in the accessories section.
Apr 04, 2011 | Computers & Internet
I sometimes get a blue screen problem, when my screen causes the system to stop. I wonder if I can update my software for my 4 years old LG laptop.
try to run disk scan for errors.
1) go to my computer.
2) right click on local disk c: drive
3) click on properties.
4) click on tools and on error- checking section click check now. on the little window mark both boxes there. and click start.
5) and finally click yes
reboot you pc and dont touch anything until the scan is finish... it automatically will fix erros if are found.
hope this help
Dec 01, 2010 | LG Computers & Internet
1/2 screen Blk w 2" Stripes & UPSIDE DOWN/drop Dell Inspiron2200
well im not a great tech but i can give you one solution, you can try to connect it to ANY monitor from the VGA port of your laptop, just find a PC monitor to do this with. to "flip" the screen to different angles you will have to be logged on.
Hope this helps, i you have any further questions just ask
Apr 10, 2009 | Dell Inspiron 2200 Notebook
ONLY THE TOP HALF OF THE SCREEN WORKS BOTTOM 2/3 FUZZY
the drivers are corupted, did it come with anytype of software, you mite have relaod the video drivers for that machine, but i would try getting any updated software.
go into control panel open up device manager, open display adapter or right click the on while on display adapter and select updated software.
www.drivershq.com
www.hp.com/drivers
hp has a very good customer service line that maybe abile to help you faster than 4 wks.
rodgandysr
Mar 11, 2009 | HP Pavilion dv6000z Notebook
Pink Vertical Line on HP dv6439nr
screen need to be replace. call hp support and get a RMA.
Oct 11, 2008 | Computers & Internet
Vertical lines in my laptop screen
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
Dec 09, 2007 | Toshiba Satellite P30 Notebook
HP Compaq nc6000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
