Question about Audiovox Bosch 718 World Cellular Phone
BOSCH CLASSIXX6 1400 EXPRESS
MY WIFE HAS PUT THE WASHER ON THIS MORNING AND WHEN SHE TURNS IT TO THE TEMPERATURE A KEY SIGN IS SHOWING AND A -0- IS FLASHING AND IT IS MAKING A BLEEPING SOUND WHAT CAN I DO TO GET IT WORKING
  • silling02 Mar 26, 2009
    exactly the same problem with classixx 6 1200 - key showing in the timer and beeping noise and won't start any cycle!! can't find my user guide - please help!!
I've just rung bosch with similar problem - they told me it's the child lock - you have to press and hold the start button for 5 plus seconds and it should go off - worked for me!
Posted on Mar 26, 2009
We have a Bosch classixx 1200 express washing machine. It is taking on average an hour longer to do a normal 110 minute 40oC spin wash.
It is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 05, 2011 | Bosch Washing Machines
Washer Bosch Classixx 6 1200 Express. The machine is displaying a "key locked" sign in the timer countdown panel. As there is no button to press to lock/unlock, how do I getr rid of this sign. ...
You need to press 2 buttons simultaneously for 3 to 7 seconds. Look for a small child's face or a lock icon (Sometimes both) on the Facial panel, there will be arrows pointing from that icon towards 2 buttons, these are the 2 you need to press.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1400 express key symbol
Apr 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Key symbol showing
Jan 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
When I select a cycle the -0- is displayed and the lock symbol.
YOU PROBABLY HAVE THE CHILD LOCK ACTIVATED GENERALLY HOLDING THE LOCK BUTTON IF THERE IS ONE OR THE START BUTTON FOR 5 SECS OR MORE WILL TURN IT OFF ALLOWING NORMAL USE
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch exxcel 1400 express
unplug the device from the mains for few minutes then check out many a times it clears the fault.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Apr 21, 2008 | Hotpoint WMA44 Front Load Washer
Audiovox Bosch 718 World Cellular Phone Logo
333 people viewed this question
Top Audiovox Cell Phones Experts
svicari124
svicari124
Level 1 Expert
Computer Repairing
Computer Repairing
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
