Question about InFocus ScreenPlay 4805 Multimedia Projector
I need a new light tunnel for my infocus X2
I need to know where i can get a new light tunnel from, my infocus projector has had little use now it's doing my nut in & by the way they knew about this problem from the start they should fix it free, now there saying that they don't make the parts for the X infocus are a rip off I will never buy there rubbish again
Was actually looking up a different problem with an X2 and came across this thread.
I do electronic repair, and often do repair on projectors with this light tunnel problem. Probably 3 a week!
I came up with a solution about a year ago. It's a tunnel peice made of highly resilient carbon fiber, lined inside with extremely reflective mirrored stainless steel.
A company here in St Louis builds them for me and I go through quite a few!
If anyone is interested, feel free to email me at mhale@ahvio.com. I charge $50 per replacement tunnel (They are pretty expensive to make). Plus $10 for shipping to anyone in the US, unless you want to come by and pick it up.
I can include a extremely easy guide to install (Its VERY easy!)
These carbon fiber replacement tubes are a solid peice, unlike the factory that is just glued together mirrors :/ They are morons! haha
I've been using this replacement tubes for about a year now and installed well over 50, so I swear by them! Very resilient to heat, and very resilient to someone installing it that isn't very careful. It's almost impossible to break!
Also sale homemade LED super high flux projector bulbs for the X1, X2, and X3. May be able to build a bulb for a different brand, depending on what the current bulb is like.
These LED bulbs have a life of 40,000+ hrs and use very little power, and produce VERY LITTLE HEAT! Cheaper to build than the factory ones, at about $175 for a complete bulb with assembly. Have about the same ANSI output as the standard bulbs, I actually think it's a little more than the rated (like 50 more lumens or so~)
If interested in either, feel free to hit me up! Willing to send parts, or can do install myself.
Posted on Mar 01, 2009
  • 138 Answers
Infocuse projector, most of model original light tunnel only cost USD79 with shipping to all over the world.
Posted on Mar 28, 2012
Mhale@ahvio.com
has them email him
best,
Tom Shaw
Posted on Mar 18, 2009
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
no it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Oct 03, 2010 | InFocus Projector Lamp for LP340, LP340B,...
X2 OHP mounted on ceiling fixture. Image is dark on right side
Yes it will have to come off the ceiling. It sounds like the light tunnel has collasped. This is located under the colorwheel. If you can get a new tunnel , be careful removing the colorwheel so no segments break off of it...make sure the new tunnel is pushed against the "lip" before screwing the tunnel clip back into place.
Aug 02, 2010 | InFocus X2 Projector
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
I have an infocus X2 projector that has a shadow on one side of the image. After reading other posts, this appears to be indicative of a light tunnel collapse. Is this problem repairable in an X2 and if so...
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Jan 29, 2010 | InFocus Office Equipment & Supplies
Infocus X2 has discolor on the left side of image- what could this be.
the light tunnel is collapsing and will need to be replaced. you could either get the part from an infocus service center or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 06, 2010 | InFocus LP290 1100 Lumen XGA LCD Projector...
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Infocus X2 shadow on right side
You are describing a light tunnel failure. Unfortunately, Infocus has decided to discontinue any parts for the X series. Your only recourse is to repair the tunnel with superglue. Or buy a new projector. If you do attempt repair, note that the corners do not line up, rather the sides are offset slightly.
Apr 15, 2008 | InFocus ScreenPlay 4805 Multimedia...
PLEASE HELP!!
It also depends what part you need because although the 3 models look similar none of the parts are compatabile with each other except maybe some body parts and the X1 and X2 share the same light tunnel but it would be a risk to assume that the light tunnel from a used model is OK. The only 2 models that share the same parts are the X1 and SP4800. The X2 is brighter and the SP4805 has a 16:9 native ratio.
Feb 11, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
894 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
